Installation & Licensing
Revit extensions 2013 HELP not found
10 REPLIES 10
Message 1 of 11
Priitl
843 Views, 10 Replies
When I click on help link in any of the Revit Extensions dialog boxes, I get the "file not found " error. How could I fix that?
File not found
Firefox can't find the file at /C:/Users/kasutaja/AppData/Roaming/Autodesk/REX/2013/DRevitModelsCompare/Help/en-US/files/GUID-2B7FD581-943C-4135-8589-75BC8AFB7A12.htm.
Check the file name for capitalization or other typing errors.
Check to see if the file was moved, renamed or deleted.
____________________________________________
If you find my post useful give me Kudos. Thank you!
If my post solved your problem, accept it as a solution.
10 REPLIES 10
Message 2 of 11
Artur.Kosakowski
in reply to: Priitl
Priitl,
Please check if the file exists in the indicated location. Tou may also try to change teh default internet browser.
I have checked this as Help opens with no problems (see teh atatched picture)
I can't see any problem copying the Help address to firefox either.
file:///C:/Users/user_name/AppData/Roaming/Autodesk/REX/2013/DRevitModelsCompare/Help/en-US/index.html?url=files/GUID-2B7FD581-943C-4135-8589-75BC8AFB7A12.htm,topicNumber=d30e20
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 3 of 11
Priitl
in reply to: Artur.Kosakowski
I have this help folder empty.
Others too.
REX\2013\DSynchAsdSteel\Help
REX\2013\DRevit2Robot\Help
REX\2013\DRevitModelsCompare\Help
Should I reinstall?
Message 4 of 11
Artur.Kosakowski
in reply to: Priitl
Try to copy from the attached file.
Artur Kosakowski
Message 5 of 11
Artur.Kosakowski
in reply to: Priitl
Artur Kosakowski
Message 6 of 11
Artur.Kosakowski
in reply to: Priitl
Artur Kosakowski
Message 7 of 11
Priitl
Thank you for your effort.
But there are more help files than those three. I  miss them all. I provided those folders as an example.
Why were they not installed?
Could you provide the whole help folder of rex?
Message 8 of 11
Artur.Kosakowski
in reply to: Priitl
Some REX modules have got help files as chm files so they are not extracted to the folders. They are to be found in the REX folder itself
For the others the help file should be extracted (when you click on the HELP link) to the folders from zip files which can be found as shown below:
Artur Kosakowski
Message 9 of 11
Priitl
I have this help folder empty. Others too. REX\2013\DSynchAsdSteel\Help REX\2013\DRevit2Robot\Help REX\2013\DRevitModelsCompare\Help Should I reinstall?
Message 10 of 11
Artur.Kosakowski
in reply to: Priitl
Please check messages 4 to 6 where I attached these Help files. Please unpack them and navigate to Help\en-US\contexthelp folders. Then run the htm file with the corresponding module name.
Artur Kosakowski
Message 11 of 11
KyleDavisCTC
in reply to: Priitl
There also isn't any help for the Element Positioning, Content Generator, Compate Models, Freeze Drawings, Shared Parameters Converter, and Text Generator.
Why are none of these provided? They should be.
I was checking all the extensions and 90% don't have a help. I need all of them.
Administrator Productivity
