• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Valued Contributor
    Revit extensions 2013 HELP not found
    354 Views, 10 Replies
    12-19-2012 02:57 AM
    When I click on help link in any of the Revit Extensions dialog boxes, I get the "file not found " error. How could I fix that?
    File not found
    Firefox can't find the file at /C:/Users/kasutaja/AppData/Roaming/Autodesk/REX/2013/DRevitModelsCompare/Help/en-US/files/GUID-2B7FD581-943C-4135-8589-75BC8AFB7A12.htm.
    Check the file name for capitalization or other typing errors.
    Check to see if the file was moved, renamed or deleted.
    ____________________________________________
    If you find my post useful give me Kudos. Thank you!
    If my post solved your problem, accept it as a solution.
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: Revit extensions 2013 HELP not found
    12-20-2012 03:48 AM in reply to: Priitl220
    Priitl,
    Please check if the file exists in the indicated location. Tou may also try to change teh default internet browser.
    I have checked this as Help opens with no problems (see teh atatched picture)
    I can't see any problem copying the Help address to firefox either.
    file:///C:/Users/user_name/AppData/Roaming/Autodesk/REX/2013/DRevitModelsCompare/Help/en-US/index.html?url=files/GUID-2B7FD581-943C-4135-8589-75BC8AFB7A12.htm,topicNumber=d30e20
    Artur Kosakowski
    Support Specialist
    Product Support
    Valued Contributor
    12-20-2012 06:00 AM in reply to: Artur.Kosakowski
    I have this help folder empty.
    Others too.
    REX\2013\DSynchAsdSteel\Help
    REX\2013\DRevit2Robot\Help
    REX\2013\DRevitModelsCompare\Help
    Should I reinstall?
    Product Support
    Artur.Kosakowski
    12-20-2012 06:05 AM in reply to: Priitl220
    Try to copy from the attached file.
    Artur Kosakowski
    Support Specialist
    Product Support
    Product Support
    Artur.Kosakowski
    12-20-2012 06:06 AM in reply to: Priitl220
    Artur Kosakowski
    Support Specialist
    Product Support
    Product Support
    Artur.Kosakowski
    12-20-2012 06:11 AM in reply to: Priitl220
    Artur Kosakowski
    Support Specialist
    Product Support
    Valued Contributor
    12-20-2012 06:33 AM in reply to: Artur.Kosakowski
    Thank you for your effort.
    But there are more help files than those three. I  miss them all. I provided those folders as an example.
    Why were they not installed?
    Could you provide the whole help folder of rex?
    Product Support
    Artur.Kosakowski
    12-20-2012 06:49 AM in reply to: Priitl220
    Some REX modules have got help files as chm files so they are not extracted to the folders. They are to be found in the REX folder itself
    For the others the help file should be extracted (when you click on the HELP link) to the folders from zip files which can be found as shown below:
    Artur Kosakowski
    Support Specialist
    Product Support
    Valued Contributor
    01-15-2013 06:07 PM in reply to: Artur.Kosakowski
    I have this help folder empty. Others too. REX\2013\DSynchAsdSteel\Help REX\2013\DRevit2Robot\Help REX\2013\DRevitModelsCompare\Help Should I reinstall?
    Product Support
    Artur.Kosakowski
    01-16-2013 01:59 AM in reply to: Priitl220
    Please check messages 4 to 6 where I attached these Help files. Please unpack them and navigate to Help\en-US\contexthelp folders. Then run the htm file with the corresponding module name.
    Artur Kosakowski
    Support Specialist
    Product Support
