Installation & Licensing
KateMorrical
Message 1 of 3 (302 Views)
Revit.exe - Entry Point Not Found
302 Views, 2 Replies
02-19-2014 10:48 AM
I recently reinstalled Revit 2013 on a computer in my office (required Microsoft's install/uninstall utility first to clean up an old version). Now it's installed, but when I try to open it I get a dialog "Revit.exe - Entry Point Not Found: The procedure entry point <> could not be located in the dynamic link library Utility.dll".
I have repaired the installation, reinstalled it, rebooted, replaced "Utility.dll" with the one from the installer directory...not sure what else to try. Any suggestions?
Kate Morrical
Digital Design Manager
Washington, DC
BIMmuse.com
Product Support
asburyj
Message 2 of 3 (276 Views)
Re: Revit.exe - Entry Point Not Found
02-20-2014 01:28 PM in reply to: KateMorrical
Hi Kate,
Sounds like you had the right idea with replacing the utility.dll. The issue could also be related to you system not being able to access or find the utility.dll. Can you check the following.
1.) Disable your antivirus or any security software and then try launching again to ensure it is not blocking access to the file.
2.) Check the permissions on the utility.dll file by going to the file properties and ensure the acocunt in question has read permissions.
3.) If the above two don't product any results, try copying the utility.dll from Revit a working system and into the non working system replacing the existing file.
If all of the above fail i would suggest a clean re-install of Revit using the instructions linked below.
http://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles/...
Jeffry Asbury
KateMorrical
Message 3 of 3 (267 Views)
02-21-2014 08:51 AM in reply to: asburyj
The clean uninstall eventaully did it. I also uninstalled an add-on that got left behind (COINS Auto-Section Box) before I tried the reinstall. Not sure if that had anything to do with it, but either way it's back now!
Thanks~
Kate Morrical
Washington, DC
BIMmuse.com
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
