Installation & Licensing
650 Views, 1 Reply
Revit error 30
I guess my problem is more the actually running and loading of revit than the actual using if it. Had it working fine V2010 Arch, then all of a sudden I couldn't open it any longer. Tried to reinstall and now I can't even get it to load again. Had 2011 loaded, but since our class was using a workbook for 2010 I never used it. Now it's telling me that I have a license error 30, failed to start AdLm (whatever that is). It wouldn't be so back if you actually get to talk to someone who might help.
Edited by
Discussion_Admin
1 REPLY 1
TravisNave
Generally speaking, product support is handled through your Value Added Reseller.
The AdLm is the Autodesk license service and your product will not launch if the licensing is broken.
Autodesk Forums:
Administrator Productivity
