Installation & Licensing
Revit claims to be installed on PC, but isn't! Help!
1 REPLY 1
1762 Views, 1 Reply
Hi, I'm having a problem installing Revit on my PC. I uninstalled Revit Architecture 2012 and attempted to install Revit 2013 until I got an error during the installation process which caused it to end prematurely. I manually deleted all the files Revit left on my computer as well as uninstalled all the other Autodesk programs I had, now the problem is when I try to install Revit again it claims to be already installed. Which no such program exists on my computer.
How can I get rid of all traces of Revit on my PC so it finally allows me to install Revit? I attached a picture which shows that thinks the program is installed.
1 REPLY 1
DannyHubbard
Microsoft has a clean up utility that should allow you to remove the Revit 2013 partial install so you can reinstall Revit.
http://support.microsoft.com/mats/Program_Install_and_Uninstall
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
Administrator Productivity
