I am trying to install Revit Structure 2012 on my laptop but it continues to give me errors. I am using Windows 8 and I will attach the install log. Please let me know if you have any sugestions.
Welcome to the community.
Autodesk 2012 products are not supported on Windows 8. However, you *might* have some luck running the setup.exe in Windows 7 compatibility mode as Administrator.
The failure on the install is due to a prerequisite. You should try to install these manually for Windows 8 versions.
Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
Keep in mind that there is no guarantee that this 2012 will work on your Windows 8. You might need to either downgrade to Windows 7 or upgrade your product to 2014.
Good Luck!
