• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    Member
    Revit Server 2013
    188 Views, 3 Replies
    02-17-2013 06:53 AM
    Maybe/hopefully someone can help. I have installed Revit Server 2013 on a Windows Server 2012 machine and everything seemed to work. I am able to connect to it via Revit Structure and can see everything on the Revit Server Administrator but I cannot save a central file. I get the "operation could not be completed" and "file not saved". I linked to a Revit Server of one of our architectural partners and can save to their server. I have Sestem, Administrator and Creator Owner on both the Cache and Projects folder.
    Any ideas or questions that I haven't thought of?
    Your help is greatly appreciated.
      Garreth
    Please use plain text.
    Member
    Re: Revit Server 2013
    02-17-2013 07:30 AM in reply to: garrethprice
    More info:
    -no AV yet on this server
    -I tried installing Revit Structure right on the server and still not able to save
    -I installed it 3 times changing the Project folder location; on the network, on the same server but different drive letter and on the same drive.
    Member
    02-18-2013 02:15 PM in reply to: garrethprice
    Still no luck. I believe I will create a new 2008r2 server and deploy the Revit Server to that as 2012 support and documentation is nonexistant.
    Active Member
    02-18-2013 06:42 PM in reply to: garrethprice
    revit server was only designed to work on server 2008 and nothing else
