Hi
I am trying to reinstall Revit from the Building Design Suite Premium 2014 USB but get the following error messages (please see attached). I have also attached the error log. Any Ideas?
Thanks.
Solved by dembkod. Go to Solution.
Solved by TravisNave. Go to Solution.
You're going to have to blow away the license files in C:\ProgramData\Autodesk\ADLM and also blow away entirely the Revit directory. Reboot, then reinstall fresh.
The pit file error may be bad. If removing the TSF file does not help, you may need to uninstall ALL Autodesk products on the machine, then delete the residual folders from here:
C:\Users\All Users\Autodesk
C:\Users\<the current user>\AppData\Local\Autodesk
C:\Users\<the current user>\AppData\Roaming\Autodesk
C:\Program Files\Common Files\Autodesk Shared
C:\Program Files\Autodesk
Thank you for taking part in our community!
Thanks for the advice which I have followed and all is .now working again.
I removed all Autodesk products, also removing files from the system registry and performed a full reinstall
