Installation & Licensing
New Member
callum.macdonald
Message 1 of 3 (518 Views)
Revit MEP 2013 Service Pack 2 Installation Error 1603
518 Views, 2 Replies
02-05-2013 01:11 AM
I'm trying to install the Revit MEP 2013 Service Update 2 and receive a 1603 error code.
I've tried all the Various solutions like uninstalling .Net, Uninstall Microsoft Visual C++ 2010 Redistributable, and or Microsoft Visual C++ 2005 Redistributable,
I Installed the Service updates for Revit Architecture 2013 & Revit Structure 2013 with no issues, Only failing with Revit MEP.
OS is Windows 7 64 Bit.
Can Anyone help?
Employee
alison.gangler
Message 2 of 3 (494 Views)
Re: Revit MEP 2013 Service Pack 2 Installation Error 1603
02-08-2013 12:13 PM in reply to: callum.macdonald
Hi Callum,
Thank you for including the install logs that were posted to the Forums thread. The cp_Install.log appears to have some connection issues to connect back to the original install source for the Content:
!=> 404 when attempt to access /download/2013RME_RTM/Content/Revit/ko/ASM-ko-XX-m-Famtem.xml
Has something changed in the configuration of your system since you first installed the application?
Did you install from a network deployment, media or install image? Perhaps you will need to have the original install media available in the same location again.
Patching has a specific mechanism whereby it has to verify the files detected on the system (Installed) and compare to the original source files to determine whether the patch file can be applied.
If you are unable to get the machine back to the original state, you can always use the workaround of uninstalling, then install again but this time choose to have the update included in the install.
Please let me know if this helps. Thank you.
Cheers,
Alison
___________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Alison Gangler
IPG - ICP Install Engineer
Autodesk, Inc.
New Member
callum.macdonald
Message 3 of 3 (474 Views)
02-11-2013 12:48 AM in reply to: alison.gangler
Log files attached,
I've used the msicrosoft fixit utility, with out any result, Have not tried the Uninstall as yet, wanted to leave that as a last resort. Th origional install was from a central deployment disk.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
