• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    Member
    Revit MEP 2012 Installation Errors
    791 Views, 7 Replies
    04-12-2012 12:25 PM
    I'm having issues installing Revit MEP 2012 (64bit) onto a brand new machine.  While upacking, the following error pops up (see attachment).  It will allow me to finish installing the program, however, a fatal error occurs when I try to create a new revit model or even open up one of the pre-made examples on the opening screen.
    Please use plain text.
    Member
    Re: Revit MEP 2012 Installation Errors
    04-12-2012 12:47 PM in reply to: jmarshall
    Here is the CER file.
    *Expert Elite*
    TravisNave
    04-12-2012 05:35 PM in reply to: jmarshall
    Are you installing as local admin with UAC off and anti-virus disabled?  You might need to redownload the product if there are possible corrupt files.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Member
    04-13-2012 08:50 AM in reply to: jmarshall
    I reinstalled with the antivirus off and managed to not get the contentpack error as before.  Now, the install says that it failed to install correctly.  This is from the log:
    Install    Microsoft VSTA Dependencies (x64) - ENU    Failed    Failure is ignored, Result=1618
    Install    Autodesk® Revit® MEP 2012    Failed    Installation aborted, Result=1618
    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1618
    Also, attached is the install log file.
    Member
    04-13-2012 11:37 AM in reply to: jmarshall
    After digging through some forums I found a similar issue with Revit Arch 2012:
    http://forums.autodesk.com/t5/Installation-Licensing/Problems-installing-Revit-Architecture-2012/td-...
    I followed Soyoung's instructions, but it only led back to the contentpack error before bringing up the install screen (after extracting files).  Ran the install again and it said that Revit installed "successfully".  But again when I opened a simple file, a fatal error occurred.  Attached is the CER.
    Product Support
    INACTIVE_Timmy.DeAustria
    04-16-2012 08:44 AM in reply to: jmarshall
    Hello jmarshall,
    I suggest that you download a new installer and do a clean uninstall
    http://usa.autodesk.com/getdoc/id=TS45252.
    Please follow directions carefully.
    Delete all files and folders associated with Revit MEP 2012
    Delete your Temp directory as well.
    Try fixing your .NET Framework using this tool here:
    http://blogs.msdn.com/b/astebner/archive/2008/08/28/8904493.aspx
    or from here:
    http://blogs.rand.com/support/2011/11/dont-fret-the-dot-net.html
    It may be quicker if you have an option to restore your new computer to factory settings, I suggest to backup all personal information and restore your machine to factory settings.
    Do a Windows Update and install Revit MEP 2012 even before any other programs.
    Good luck and please let me know and how it goes.
    Timmy De Austria
    Product Support | Up and Ready Blog | If my reply was helpful, please Kudo or Accept as Solution. :smileywink:
    New Member
    03-17-2013 03:41 PM in reply to: jmarshall
    helloo can you help me this pls...
    *Expert Elite*
    TravisNave
    03-22-2013 12:13 PM in reply to: DERF_0991
    Run as Administrator.  Make sure Internet Explorer is up-to-date and is your default browser.
    Travis Nave
