I just installed Revit Lt 2013. Installation seemed fine but when I attempt to start a new drawing there are no templates to choose from. Also if I start one from scratch there is only one "basic" wall type. Level and section lines do not seem to show correctly either. I am a novice to the program so it may just be me but I do recall trying a full blown version and it seemed elevation and section references were easy to manipulate . Can someone tell me if this is an installation problem, program limitation or a user problem.
Thanks for your help. I tried this and it did not work so I tried again but this time used the "Add or Remove" instead of the "Repair or Reinstall" action and then clicked the "add content". That did the trick. Now it works very well.
Very Good.
I am glad you were able to resolve.
I will remember the ADD CONTENT solution,
