Installation & Licensing
New Member
radiusdesign
Message 1 of 4 (169 Views)
Revit Lt 2013
169 Views, 3 Replies
02-01-2013 02:02 PM
I just installed Revit Lt 2013. Installation seemed fine but when I attempt to start a new drawing there are no templates to choose from. Also if I start one from scratch there is only one "basic" wall type. Level and section lines do not seem to show correctly either. I am a novice to the program so it may just be me but I do recall trying a full blown version and it seemed elevation and section references were easy to manipulate . Can someone tell me if this is an installation problem, program limitation or a user problem.
Lineabove
Message 2 of 4 (158 Views)
Re: Revit Lt 2013
02-01-2013 03:05 PM in reply to: radiusdesign
Only suggestion I can make is to do a repair install.
New Member
radiusdesign
Message 3 of 4 (122 Views)
Re: Revit Lt 2013
02-04-2013 05:54 AM in reply to: Lineabove
Thanks for your help. I tried this and it did not work so I tried again but this time used the "Add or Remove" instead of the "Repair or Reinstall" action and then clicked the "add content".  That did the trick. Now it works very well.
Lineabove
Message 4 of 4 (115 Views)
Re: Revit Lt 2013
02-04-2013 09:16 AM in reply to: radiusdesign
Very Good.
I am glad you were able to resolve.
I will remember the ADD CONTENT solution,
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
