Installation & Licensing
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Revit Installati on problems
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi, i've spent like 5 hours renaming files, moving files re-installing and uninstalling lot of programs and still get error message.
Installing Microsoft Visual C++ 2005 Redistributable (x64): H:\Autodesk\Autodesk_Revit_2013_English_Win_32-64b
2012/10/29:13:11:43 Liam# LIAM-PC Install Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=2
Is the error message which i am currently getting, does anyone know anyway to solve this with out having to reinstall windows, as i have alot of data and no where to put it.
Liam
Re: Revit Installati on problems
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Liam,
Can you post the "C:\Users\Liam#\AppData\Local\Temp\vcredist_x64_20
Danny
Danny Hubbard
QA Analyst
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
ummm, i check my temp files, however that file is not present anywhere on my computer. i've searched each one of my harddrives and stilll nothing.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I get a similar error in trying to install Revit MEP 2013. I cannot locate the temporary file but the error code is 1639. When you click on the link (from trying to install and it comes back stating it had failed), the biggest item I saw was C++2005 version. However, on the help portion of that link, it only listed error code 1609, not the 1639 as I was having.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Liam,
You could try installing the Redistributable directly from Microsoft then run the Setup for Revit again.
http://www.microsoft.com/en-us/download/details.as
Danny
Danny Hubbard
QA Analyst
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks danny,
There was a problem with the 2005 C++, but i was able to repair the 2008 C++, however it failed to install again, and this error appeared now:
2012/10/29:21:30:25 Liam# LIAM-PC === Setup started on LIAM-PC by Liam# ===
2012/10/29:21:30:25 Liam# LIAM-PC Launch
2012/10/29:21:30:37 Liam# LIAM-PC PageOpen LaunchDialog
2012/10/29:21:30:41 Liam# LIAM-PC PageOpen LicenseDialog
2012/10/29:21:30:43 Liam# LIAM-PC PageOpen ProductInfoDialog
2012/10/29:21:31:36 Liam# LIAM-PC PageOpen ProductSelectionDialog2
2012/10/29:21:31:57 Liam# LIAM-PC PageOpen FullProgressDialog
2012/10/29:21:31:57 Liam# LIAM-PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Program Files (x86)\Autodesk\3rdParty\x86\VCRedist\2010SP1\vcred
2012/10/29:21:32:06 Liam# LIAM-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2012/10/29:21:32:06 Liam# LIAM-PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Program Files (x86)\Autodesk\3rdParty\x64\VCRedist\2010SP1\vcred
2012/10/29:21:32:16 Liam# LIAM-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2012/10/29:21:32:16 Liam# LIAM-PC Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Program Files (x86)\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/10/29:21:32:22 Liam# LIAM-PC Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2012/10/29:21:32:22 Liam# LIAM-PC Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Program Files (x86)\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/10/29:21:32:33 Liam# LIAM-PC Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2012/10/29:21:32:33 Liam# LIAM-PC Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Program Files (x86)\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/10/29:21:32:44 Liam# LIAM-PC Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2012/10/29:21:32:44 Liam# LIAM-PC Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Program Files (x86)\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/10/29:21:32:53 Liam# LIAM-PC Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2012/10/29:21:32:53 Liam# LIAM-PC Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Program Files (x86)\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/10/29:21:32:58 Liam# LIAM-PC Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2012/10/29:21:32:58 Liam# LIAM-PC Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Program Files (x86)\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/10/29:21:33:09 Liam# LIAM-PC Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2012/10/29:21:33:09 Liam# LIAM-PC Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Program Files (x86)\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/10/29:21:33:18 Liam# LIAM-PC Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2012/10/29:21:33:18 Liam# LIAM-PC Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Program Files (x86)\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/10/29:21:33:26 Liam# LIAM-PC Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2012/10/29:21:33:26 Liam# LIAM-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Program Files (x86)\Autodesk\3rdParty\x86\VCRedist\2005SP1ATL\vc
2012/10/29:21:33:26 Liam# LIAM-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2012/10/29:21:33:32 Liam# LIAM-PC Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2012/10/29:21:33:36 Liam# LIAM-PC Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2012/10/29:21:33:42 Liam# LIAM-PC Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2012/10/29:21:33:46 Liam# LIAM-PC Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2012/10/29:21:33:50 Liam# LIAM-PC Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2012/10/29:21:33:55 Liam# LIAM-PC Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2012/10/29:21:33:59 Liam# LIAM-PC Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2012/10/29:21:34:02 Liam# LIAM-PC Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2012/10/29:21:34:02 Liam# LIAM-PC Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2012/10/29:21:34:02 Liam# LIAM-PC Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
Hope this helps us get to the bottom of the problem.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
hi sorry to bring this up again,
I've been away. Right trying to reinstall the 2005 SP1 X64 package:
Leads to - <C:\Users\LiamAppData\Local\Temp\IXP001.TMP\VCREDI
doing the same witht he 86 version leads to :
<C:\Users\LiamAppData\Local\Temp\IXP000.TMP\VCREDI
Tried to install again and this is what i got :
2012/11/18:20:35:04 Liam# LIAM-PC === Setup started on LIAM-PC by Liam# ===
2012/11/18:20:35:04 Liam# LIAM-PC Launch
2012/11/18:20:35:12 Liam# LIAM-PC === Setup ended ===
2012/11/18:20:35:06 Liam# LIAM-PC === Setup started on LIAM-PC by Liam# ===
2012/11/18:20:35:06 Liam# LIAM-PC Launch
2012/11/18:20:35:11 Liam# LIAM-PC PageOpen LaunchDialog
2012/11/18:20:35:24 Liam# LIAM-PC PageOpen LicenseDialog
2012/11/18:20:35:26 Liam# LIAM-PC PageOpen ProductInfoDialog
2012/11/18:20:36:11 Liam# LIAM-PC PageOpen ProductSelectionDialog2
2012/11/18:20:37:32 Liam# LIAM-PC PageOpen ProductInfoDialog
2012/11/18:20:37:34 Liam# LIAM-PC PageOpen ProductSelectionDialog2
2012/11/18:20:37:45 Liam# LIAM-PC PageOpen FullProgressDialog
2012/11/18:20:37:46 Liam# LIAM-PC Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\Autodesk\Autodesk_Revit_2013_
2012/11/18:20:37:54 Liam# LIAM-PC Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2012/11/18:20:37:54 Liam# LIAM-PC Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\Autodesk\Autodesk_Revit_2013_
2012/11/18:20:38:08 Liam# LIAM-PC Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2012/11/18:20:38:08 Liam# LIAM-PC Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\Autodesk\Autodesk_Revit_2013_
2012/11/18:20:38:19 Liam# LIAM-PC Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2012/11/18:20:38:19 Liam# LIAM-PC Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\Autodesk\Autodesk_Revit_2013_
2012/11/18:20:38:30 Liam# LIAM-PC Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2012/11/18:20:38:30 Liam# LIAM-PC Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\Autodesk\Autodesk_Revit_2013_
2012/11/18:20:38:36 Liam# LIAM-PC Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2012/11/18:20:38:36 Liam# LIAM-PC Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\Autodesk\Autodesk_Revit_2013_
2012/11/18:20:38:54 Liam# LIAM-PC Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2012/11/18:20:38:54 Liam# LIAM-PC Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\Autodesk\Autodesk_Revit_2013_
2012/11/18:20:39:07 Liam# LIAM-PC Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2012/11/18:20:39:07 Liam# LIAM-PC Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\Autodesk\Autodesk_Revit_2013_
2012/11/18:20:39:18 Liam# LIAM-PC Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2012/11/18:20:39:18 Liam# LIAM-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): H:\Autodesk\Autodesk_Revit_2013_English_Win_32-64b
2012/11/18:20:39:18 Liam# LIAM-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2012/11/18:20:39:25 Liam# LIAM-PC Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2012/11/18:20:39:30 Liam# LIAM-PC Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2012/11/18:20:39:35 Liam# LIAM-PC Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2012/11/18:20:39:39 Liam# LIAM-PC Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2012/11/18:20:39:44 Liam# LIAM-PC Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2012/11/18:20:39:49 Liam# LIAM-PC Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2012/11/18:20:39:55 Liam# LIAM-PC Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2012/11/18:20:39:59 Liam# LIAM-PC Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
Please help me
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hello.
I keep getting the same error:
Error 1935. An error occured during the installation of assembly 'Microsoft.VC90.ATL,version"9.0.30729.177",publicK
The log file says:
Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\Britni\Desktop\Autodesk
I have Win 7 64-bit and have uninstalled Visual C++ 2008 and 2010 and only have Visual C++2005 on my machine. I have tried "Download Now" and "Browser Download" and both fail. Please assist. Thank you
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You should probably start with this document from Microsoft on the error you are getting.
http://support.microsoft.com/kb/970652
Danny
Danny Hubbard
QA Analyst
