• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    Member
    Revit Installation problems
    846 Views, 8 Replies
    10-29-2012 06:27 AM
    Hi, i've spent like 5 hours renaming files, moving files re-installing and uninstalling lot of programs and still get error message.
    Installing Microsoft Visual C++ 2005 Redistributable (x64): H:\Autodesk\Autodesk_Revit_2013_English_Win_32-64bit\3rdParty\x64\VCRedist\2005\vcredist_x64.exe /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Liam#\AppData\Local\Temp\vcredist_x64_2005.log"" "
    2012/10/29:13:11:43    Liam#    LIAM-PC    Install    Microsoft Visual C++ 2005 Redistributable (x64)    Failed    Installation aborted, Result=2
    Is the error message which i am currently getting, does anyone know anyway to solve this with out having to reinstall windows, as i have alot of data and no where to put it.
    Liam
    Please use plain text.
    Employee
    Re: Revit Installation problems
    10-29-2012 08:03 AM in reply to: liamwhitmore
    Liam,
    Can you post the "C:\Users\Liam#\AppData\Local\Temp\vcredist_x64_2005.log" file, should have more information as to why the redistributable cannot be installed.
    Danny
    Danny Hubbard
    QA Analyst
    Autodesk, Inc.
    Member
    10-29-2012 08:41 AM in reply to: liamwhitmore
    ummm, i check my temp files, however that file is not present anywhere on my computer. i've searched each one of my harddrives and stilll nothing.
    New Member
    10-29-2012 09:27 AM in reply to: liamwhitmore
    I get a similar error in trying to install Revit MEP 2013.  I cannot locate the temporary file but the error code is 1639.  When you click on the link (from trying to install and it comes back stating it had failed), the biggest item I saw was C++2005 version.  However, on the help portion of that link, it only listed error code 1609, not the 1639 as I was having.
    Employee
    10-29-2012 10:24 AM in reply to: liamwhitmore
    Liam,
    You could try installing the Redistributable directly from Microsoft then run the Setup for Revit again.
    http://www.microsoft.com/en-us/download/details.aspx?id=18471
    Danny
    Danny Hubbard
    QA Analyst
    Autodesk, Inc.
    Member
    10-29-2012 02:39 PM in reply to: DannyHubbard
    Thanks danny,
    There was a problem with the 2005 C++, but i was able to repair the 2008 C++, however it failed to install again, and this error appeared now:
    2012/10/29:21:30:25    Liam#    LIAM-PC    === Setup started on LIAM-PC by Liam# ===
    2012/10/29:21:30:25    Liam#    LIAM-PC    Launch
    2012/10/29:21:30:37    Liam#    LIAM-PC    PageOpen    LaunchDialog
    2012/10/29:21:30:41    Liam#    LIAM-PC    PageOpen    LicenseDialog
    2012/10/29:21:30:43    Liam#    LIAM-PC    PageOpen    ProductInfoDialog
    2012/10/29:21:31:36    Liam#    LIAM-PC    PageOpen    ProductSelectionDialog2
    2012/10/29:21:31:57    Liam#    LIAM-PC    PageOpen    FullProgressDialog
    2012/10/29:21:31:57    Liam#    LIAM-PC    Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Program Files (x86)\Autodesk\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart
    2012/10/29:21:32:06    Liam#    LIAM-PC    Install    Microsoft Visual C++ 2010 SP1 Redistributable (x86)    Succeeded
    2012/10/29:21:32:06    Liam#    LIAM-PC    Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Program Files (x86)\Autodesk\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart
    2012/10/29:21:32:16    Liam#    LIAM-PC    Install    Microsoft Visual C++ 2010 SP1 Redistributable (x64)    Succeeded
    2012/10/29:21:32:16    Liam#    LIAM-PC    Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Program Files (x86)\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
     2012/10/29:21:32:22    Liam#    LIAM-PC    Install    Microsoft Visual C++ 2008 KB958314 (ATL) (x86)    Succeeded
    2012/10/29:21:32:22    Liam#    LIAM-PC    Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Program Files (x86)\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
     2012/10/29:21:32:33    Liam#    LIAM-PC    Install    Microsoft Visual C++ 2008 KB958314 (MFC) (x86)    Succeeded
    2012/10/29:21:32:33    Liam#    LIAM-PC    Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Program Files (x86)\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
     2012/10/29:21:32:44    Liam#    LIAM-PC    Install    Microsoft Visual C++ 2008 KB958314 (CRT) (x86)    Succeeded
    2012/10/29:21:32:44    Liam#    LIAM-PC    Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Program Files (x86)\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
     2012/10/29:21:32:53    Liam#    LIAM-PC    Install    Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86)    Succeeded
    2012/10/29:21:32:53    Liam#    LIAM-PC    Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Program Files (x86)\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
     2012/10/29:21:32:58    Liam#    LIAM-PC    Install    Microsoft Visual C++ 2008 KB958314 (ATL) (x64)    Succeeded
    2012/10/29:21:32:58    Liam#    LIAM-PC    Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Program Files (x86)\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
     2012/10/29:21:33:09    Liam#    LIAM-PC    Install    Microsoft Visual C++ 2008 KB958314 (MFC) (x64)    Succeeded
    2012/10/29:21:33:09    Liam#    LIAM-PC    Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Program Files (x86)\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
     2012/10/29:21:33:18    Liam#    LIAM-PC    Install    Microsoft Visual C++ 2008 KB958314 (CRT) (x64)    Succeeded
    2012/10/29:21:33:18    Liam#    LIAM-PC    Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Program Files (x86)\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
     2012/10/29:21:33:26    Liam#    LIAM-PC    Install    Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64)    Succeeded
    2012/10/29:21:33:26    Liam#    LIAM-PC    Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Program Files (x86)\Autodesk\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Liam#\AppData\Local\Temp\vcredist_x86_2005.log"" "
    2012/10/29:21:33:26    Liam#    LIAM-PC    Install    Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86)    Failed    Installation aborted, Result=1603
    2012/10/29:21:33:32    Liam#    LIAM-PC    Rollback    Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64)    Succeeded
    2012/10/29:21:33:36    Liam#    LIAM-PC    Rollback    Microsoft Visual C++ 2008 KB958314 (CRT) (x64)    Succeeded
    2012/10/29:21:33:42    Liam#    LIAM-PC    Rollback    Microsoft Visual C++ 2008 KB958314 (MFC) (x64)    Succeeded
    2012/10/29:21:33:46    Liam#    LIAM-PC    Rollback    Microsoft Visual C++ 2008 KB958314 (ATL) (x64)    Succeeded
    2012/10/29:21:33:50    Liam#    LIAM-PC    Rollback    Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86)    Succeeded
    2012/10/29:21:33:55    Liam#    LIAM-PC    Rollback    Microsoft Visual C++ 2008 KB958314 (CRT) (x86)    Succeeded
    2012/10/29:21:33:59    Liam#    LIAM-PC    Rollback    Microsoft Visual C++ 2008 KB958314 (MFC) (x86)    Succeeded
    2012/10/29:21:34:02    Liam#    LIAM-PC    Rollback    Microsoft Visual C++ 2008 KB958314 (ATL) (x86)    Succeeded
    2012/10/29:21:34:02    Liam#    LIAM-PC    Rollback    Microsoft Visual C++ 2010 SP1 Redistributable (x64)    Failed    Installation aborted, Result=1619
    2012/10/29:21:34:02    Liam#    LIAM-PC    Rollback    Microsoft Visual C++ 2010 SP1 Redistributable (x86)    Failed    Installation aborted, Result=1619
    Hope this helps us get to the bottom of the problem.
    Member
    11-18-2012 12:34 PM in reply to: DannyHubbard
    hi sorry to bring this up again,
    I've been away. Right trying to reinstall the 2005 SP1 X64 package:
    Leads to - <C:\Users\LiamAppData\Local\Temp\IXP001.TMP\VCREDI~2.EXE
    doing the same witht he 86 version leads to :
    <C:\Users\LiamAppData\Local\Temp\IXP000.TMP\VCREDI~1.EXE
    Tried to install again and this is what i got :
    2012/11/18:20:35:04    Liam#    LIAM-PC    === Setup started on LIAM-PC by Liam# ===
    2012/11/18:20:35:04    Liam#    LIAM-PC    Launch
    2012/11/18:20:35:12    Liam#    LIAM-PC    === Setup ended ===
    2012/11/18:20:35:06    Liam#    LIAM-PC    === Setup started on LIAM-PC by Liam# ===
    2012/11/18:20:35:06    Liam#    LIAM-PC    Launch
    2012/11/18:20:35:11    Liam#    LIAM-PC    PageOpen    LaunchDialog
    2012/11/18:20:35:24    Liam#    LIAM-PC    PageOpen    LicenseDialog
    2012/11/18:20:35:26    Liam#    LIAM-PC    PageOpen    ProductInfoDialog
    2012/11/18:20:36:11    Liam#    LIAM-PC    PageOpen    ProductSelectionDialog2
    2012/11/18:20:37:32    Liam#    LIAM-PC    PageOpen    ProductInfoDialog
    2012/11/18:20:37:34    Liam#    LIAM-PC    PageOpen    ProductSelectionDialog2
    2012/11/18:20:37:45    Liam#    LIAM-PC    PageOpen    FullProgressDialog
    2012/11/18:20:37:46    Liam#    LIAM-PC    Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\Autodesk\Autodesk_Revit_2013_English_Win_32-64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
     2012/11/18:20:37:54    Liam#    LIAM-PC    Install    Microsoft Visual C++ 2008 KB958314 (ATL) (x86)    Succeeded
    2012/11/18:20:37:54    Liam#    LIAM-PC    Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\Autodesk\Autodesk_Revit_2013_English_Win_32-64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
     2012/11/18:20:38:08    Liam#    LIAM-PC    Install    Microsoft Visual C++ 2008 KB958314 (MFC) (x86)    Succeeded
    2012/11/18:20:38:08    Liam#    LIAM-PC    Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\Autodesk\Autodesk_Revit_2013_English_Win_32-64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
     2012/11/18:20:38:19    Liam#    LIAM-PC    Install    Microsoft Visual C++ 2008 KB958314 (CRT) (x86)    Succeeded
    2012/11/18:20:38:19    Liam#    LIAM-PC    Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\Autodesk\Autodesk_Revit_2013_English_Win_32-64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
     2012/11/18:20:38:30    Liam#    LIAM-PC    Install    Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86)    Succeeded
    2012/11/18:20:38:30    Liam#    LIAM-PC    Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\Autodesk\Autodesk_Revit_2013_English_Win_32-64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
     2012/11/18:20:38:36    Liam#    LIAM-PC    Install    Microsoft Visual C++ 2008 KB958314 (ATL) (x64)    Succeeded
    2012/11/18:20:38:36    Liam#    LIAM-PC    Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\Autodesk\Autodesk_Revit_2013_English_Win_32-64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
     2012/11/18:20:38:54    Liam#    LIAM-PC    Install    Microsoft Visual C++ 2008 KB958314 (MFC) (x64)    Succeeded
    2012/11/18:20:38:54    Liam#    LIAM-PC    Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\Autodesk\Autodesk_Revit_2013_English_Win_32-64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
     2012/11/18:20:39:07    Liam#    LIAM-PC    Install    Microsoft Visual C++ 2008 KB958314 (CRT) (x64)    Succeeded
    2012/11/18:20:39:07    Liam#    LIAM-PC    Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\Autodesk\Autodesk_Revit_2013_English_Win_32-64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
     2012/11/18:20:39:18    Liam#    LIAM-PC    Install    Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64)    Succeeded
    2012/11/18:20:39:18    Liam#    LIAM-PC    Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): H:\Autodesk\Autodesk_Revit_2013_English_Win_32-64bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Liam#\AppData\Local\Temp\vcredist_x86_2005.log"" "
    2012/11/18:20:39:18    Liam#    LIAM-PC    Install    Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86)    Failed    Installation aborted, Result=1603
    2012/11/18:20:39:25    Liam#    LIAM-PC    Rollback    Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64)    Succeeded
    2012/11/18:20:39:30    Liam#    LIAM-PC    Rollback    Microsoft Visual C++ 2008 KB958314 (CRT) (x64)    Succeeded
    2012/11/18:20:39:35    Liam#    LIAM-PC    Rollback    Microsoft Visual C++ 2008 KB958314 (MFC) (x64)    Succeeded
    2012/11/18:20:39:39    Liam#    LIAM-PC    Rollback    Microsoft Visual C++ 2008 KB958314 (ATL) (x64)    Succeeded
    2012/11/18:20:39:44    Liam#    LIAM-PC    Rollback    Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86)    Succeeded
    2012/11/18:20:39:49    Liam#    LIAM-PC    Rollback    Microsoft Visual C++ 2008 KB958314 (CRT) (x86)    Succeeded
    2012/11/18:20:39:55    Liam#    LIAM-PC    Rollback    Microsoft Visual C++ 2008 KB958314 (MFC) (x86)    Succeeded
    2012/11/18:20:39:59    Liam#    LIAM-PC    Rollback    Microsoft Visual C++ 2008 KB958314 (ATL) (x86)    Succeeded
    Please help me :smileysad:,
    New Member
    03-12-2013 03:17 AM in reply to: liamwhitmore
    Hello.
    I keep getting the same error:
    Error 1935. An error occured during the installation of assembly 'Microsoft.VC90.ATL,version"9.0.30729.177",publicKeyToken="1fc8b3b9a1e18e3b",processArchitecture="x86",type="win32".Please refer to Help and Support for more information
    The log file says:
    Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\Britni\Desktop\Autodesk_Revit_2013_English_Win_32bit-64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
    I have Win 7 64-bit and have uninstalled Visual C++ 2008 and 2010 and only have Visual C++2005 on my machine. I have tried "Download Now" and "Browser Download" and both fail. Please assist. Thank you
    Employee
    03-12-2013 04:31 AM in reply to: bisforbritni
    You should probably start with this document from Microsoft on the error you are getting.
    http://support.microsoft.com/kb/970652
    Danny
    Danny Hubbard
    QA Analyst
    Autodesk, Inc.
