Installation & Licensing
Member
Bretto75
Message 1 of 4 (2,279 Views)
Revit Extensions for Autodesk Revit 2013 installation problem
2279 Views, 3 Replies
04-25-2012 11:40 PM
Every time i try to install the extension pack it fails - I have attched the log but it dosent seen to say what the problem is, anyone having this problem.
2012/2/6:06:38:41 User USER-PC === Setup started on USER-PC by User === 2012/2/6:06:38:41 User USER-PC Launch 2012/2/6:06:38:43 User USER-PC === Setup ended ===
2012/2/6:06:38:41 User USER-PC === Setup started on USER-PC by User === 2012/2/6:06:38:41 User USER-PC Launch 2012/2/6:06:38:44 User USER-PC PageOpen LaunchDialog   2012/2/6:06:38:47 User USER-PC PageOpen LicenseDialog   2012/2/6:06:38:52 User USER-PC PageOpen ProductSelectionDialog2   2012/2/6:06:38:57 User USER-PC PageOpen FullProgressDialog   2012/2/6:06:38:57 User USER-PC Installing Autodesk® Revit Extensions for Revit Structure 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\Program Files\Autodesk\Revit Structure 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/2/6:06:40:51 User USER-PC Install Autodesk® Revit Extensions for Revit Structure 2012 Succeeded  2012/2/6:06:40:51 User USER-PC PageOpen InstallCompleteDialog   2012/2/6:07:42:59 User USER-PC === Setup ended ===
2012/2/6:06:49:25 User USER-PC === Setup started on USER-PC by User === 2012/2/6:06:49:25 User USER-PC Launch 2012/2/6:06:49:25 User USER-PC An instance of setup is already running. Only one instance of setup can run at a time.2012/2/6:07:56:04 User USER-PC === Setup ended ===
2012/4/26:16:01:43 User USER-PC === Setup started on USER-PC by User === 2012/4/26:16:01:43 User USER-PC Launch 2012/4/26:16:01:46 User USER-PC === Setup ended ===
2012/4/26:16:01:44 User USER-PC === Setup started on USER-PC by User === 2012/4/26:16:01:44 User USER-PC Launch 2012/4/26:16:01:45 User USER-PC PageOpen LaunchDialog   2012/4/26:16:04:32 User USER-PC PageOpen LicenseDialog   2012/4/26:16:04:37 User USER-PC PageOpen ProductSelectionDialog2   2012/4/26:16:04:44 User USER-PC PageOpen LicenseDialog   2012/4/26:16:04:46 User USER-PC PageOpen ProductSelectionDialog2   2012/4/26:16:04:51 User USER-PC PageOpen FullProgressDialog   2012/4/26:16:04:52 User USER-PC Installing Autodesk® Revit Extensions for Revit 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\REX_RVT_2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/4/26:16:04:52 User USER-PC Install Autodesk® Revit Extensions for Revit 2013 Failed Installation aborted, Result=1622
Member
Bretto75
Message 2 of 4 (2,239 Views)
Re: Revit Extensions for Autodesk Revit 2013 installation problem
04-27-2012 03:34 PM in reply to: Bretto75
Problem solved - I can the extension pack as Administrator and it installed with no problems this time.
abhijit.ghosh
Message 3 of 4 (1,674 Views)
05-25-2012 12:01 AM in reply to: Bretto75
Can you please give me the link for this add-ins (Revit Extensions for Autodesk Revit Structure 2013) from where we download the exe? Thanks in advance.
DarrenP
Message 4 of 4 (1,663 Views)
05-25-2012 05:37 AM in reply to: abhijit.ghosh
you have to be on subscription to download it
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
