I'm trying to download and install Revit student. I have windows 8.1.
The error states it a "Communication Failure" but I'm direct connect to internet and have full bars. I've turned off the firewall.
I'm still I'm getting the failure (see attached picture).
I've tried all 3 download options and I can't get it to work.
Please help........Thank you,
Melissa
Solved by jessica.t. Go to Solution.
Try the virtual assistant method.
Good Luck!
i was wondering if you found the solution, im having the same issues and the virtual agent does not help and the other download method is not working.
soobia.jamal@gmail.com
Hi @Anonymous and welcome to the community!
If you need Revit and you're working with a Windows 8.1 operating system you will need to use the 2015 version. Please see the system requirements for further details. There likely will not be a patch for previous version products to become compatible with 8.1.
If you have any other questions please let us know. Thanks!
Sigh, I'm facing the same problem too, once I finished download it says 'installation complete. some products failed to install'. This is exremely annoying.
Hi @guat.toh
Are you trying to install Revit 2015? Please, note that Revit is the only version supported on Winddows 8.1.
If you are trying to install the 2015 version and are getting the "Some Products Failed to Install" error, please try the solution described on this link.
Thank you,
Hi @Anonymous,
Thank you for the additional information! However, there isn't an attachment with your post. If you could please re-attach it to your reply that would be great. Thanks!
I've tried repeatedly to get Revit 2015 to install on my new 8.1 laptop and it fails everytime. Has anyone figure out how to correct this? I need to know if I should rerturn this laptop and get windows 8.
Erica,
Post your installation log. Microsoft is forcing 8.1 on all 8.0 users anyway, so switching up isn't going to do any good. If you are having download issues, try the virtual assistant.
Good Luck!
Hi Erica...
I ended up disabling my firewall and installing via "Browser Download". It takes a really long time, but it worked!
Hope this helps.
Hi guys,
I managed to download revit 2015. I'm student and was given the serial number and product key.
However, my product key doesn't work at all.
Is this something to do with the installation?
