Revit is failing to install correctly on my computer. I downloaded my copy for educational purposes and, though Design Review 2012 installed nicely, Revit Architecture 2012 did not. The final code for my installation was as follows:
2011/10/29:01:37:09 Eric RAGNAROK === Setup started on RAGNAROK by Eric ===
2011/10/29:01:37:09 Eric RAGNAROK Launch
2011/10/29:01:38:18 Eric RAGNAROK PageOpen LaunchDialog
2011/10/29:01:40:26 Eric RAGNAROK PageOpen LicenseDialog
2011/10/29:01:40:31 Eric RAGNAROK PageOpen ProductInfoDialog
2011/10/29:01:40:49 Eric RAGNAROK PageOpen ProductSelectionDialog2
2011/10/29:01:42:19 Eric RAGNAROK PageOpen FullProgressDialog
2011/10/29:01:42:19 Eric RAGNAROK Installing DirectX® Runtime: C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\DirectX\DXSETUP.exe /silent
2011/10/29:01:43:17 Eric RAGNAROK Install DirectX® Runtime Succeeded
2011/10/29:01:43:18 Eric RAGNAROK Installing Autodesk® Revit® Architecture 2012: TRANSFORMS="C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\x86\en-us\RAC2012\RAC2012.mst;C:\Users\Eric\AppData\Local\Temp\_AI7870.tmp\x86\RAC2012\RAC2012-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/10/29:01:43:18 Eric RAGNAROK Install Autodesk® Revit® Architecture 2012 Failed Installation aborted, Result=1618
2011/10/29:01:43:18 Eric RAGNAROK Rollback DirectX® Runtime Failed Failure is ignored, Result=1618
I need Revit so I can get through my certification process. I've tried to install several times now with the same result. What do I need to do to install Revit completely?
-Eric
These errors can indicate anything. It's very difficult to troubleshoot. I would re-download the package and re-install.
