Installation & Licensing
Revit/AutoCAD Locks Up On Activation
5 REPLIES 5
313 Views, 5 Replies
So, I recently re-installed my Building Design Suite 2013, and upon activation, it told me I was out of activations (understandable).  I called Autodesk and got an activation code, but every time I input the code that was given to me, the activation screen freezes and forces me to close it down.
Stuck with a fresh installation of Building Design Suite that I can't use because the activation screen freezes and doesn't work.
Any suggestions?  I've tried the IE 8 downgrade solution for the "blank activation screen" issue, but that didn't work.
5 REPLIES 5
TravisNave
Does this happen with all the products in the suite?  If you can activate one of them, then it will activate all of them.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Yes, I've tried this with every program in the suite, and it does the same thing every time.
I even tried uninstalling and reinstalling.  I'm at a loss.  I've tried everything I can think of, and severl things I've found online.  Unless I can get some help through the gurus here, I may end up having to reinstall the entire windows installation.  So frustrating.
TravisNave
Try logging in as a different user, like local administrator.
Autodesk Forums:
in reply to: TravisNave
I am logged in as the local administrator...
Administrator Productivity
