Installation & Licensing
Revit Architecture-Accessing a network license remotely
1 REPLY 1
490 Views, 1 Reply
I have Revit on my laptop and usually access the license at work with direct hard connection.
I would like to use the software remotely and access the license. I already have a VPN connection
and can access the network from home.
Any solutions???
1 REPLY 1
TravisNave
This should work. If you are connected via VPN and you can ping the name of your license server, then you should have no problem launching your product. Due to the slower connections assciated with a VPN, you may have to increase the FLEXLM_TIMEOUT system environment variable to something large. I generally recommend setting it to 1000000.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
