• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    carrillogov
    Revit Architecture 2012 fails on installation
    250 Views, 4 Replies
    01-31-2012 05:07 PM
    the program keeps on failing to install correctly whenever it gets to the directx stage i have a windows vista OS please help been at it for 2 days and i need this software for a class
    ***Guru
    TravisNave
    Re: Revit Architecture 2012 fails on installation
    02-01-2012 07:03 AM in reply to: carrillogov
    Include any relevant installation log files from your %TEMP% folder and any screen captures that might help.
    My Top Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Administrator | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combining .LIC Files | Search Autodesk Discussion Groups
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    New Member
    carrillogov
    02-07-2012 07:05 PM in reply to: TravisNave
    here it the log file
    ***Guru
    TravisNave
    02-08-2012 07:35 AM in reply to: carrillogov
    Install Microsoft Visual C++ 2005 Redistributable (x86) Failed
    Go into your Control Panel > Programs and locate your Visual C++ 2005.  Select it and uninstall it.  Then run your Autodesk installer again.  It should reinstall this prerequisite and continue the installation.
    New Member
    AlexPestrev7583
    02-08-2012 11:42 AM in reply to: carrillogov
     I have same problem, but I can not ininstall Microsoft C++ 2010 Redistributibal. There is simply NO uninstall option for that in Windows 7 SP1. I found Visual Studio 2010 Uninstall Utility on MSDN Microsoft site, but it only works if I remove SP1. When I've read instraction about uinstalling SP1 I discovered that (I quote note from Microsoft site) "
    If you installed SP1 yourself, you can uninstall it. However, if your computer came with SP1 already installed, it can't be uninstalled."
    And we just got new computers with SP1 preinstalled. So, I can not uninstall C++ 2010 and I can not uninstall SP1 in order to install Revit 2012.
     Is there really one option left - to reinstall Windows 7?
