Installation & Licensing
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Revit Architectu re 2012 fails on installati on
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
the program keeps on failing to install correctly whenever it gets to the directx stage i have a windows vista OS please help been at it for 2 days and i need this software for a class
Re: Revit Architectu re 2012 fails on installati on
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Include any relevant installation log files from your %TEMP% folder and any screen captures that might help.
My Top Contributions to the Discussion Groups:
FLEXnet License Administrator | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combining .LIC Files |
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: Revit Architectu re 2012 fails on installati on
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
here it the log file
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Install Microsoft Visual C++ 2005 Redistributable (x86) Failed
Go into your Control Panel > Programs and locate your Visual C++ 2005. Select it and uninstall it. Then run your Autodesk installer again. It should reinstall this prerequisite and continue the installation.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have same problem, but I can not ininstall Microsoft C++ 2010 Redistributibal. There is simply NO uninstall option for that in Windows 7 SP1. I found Visual Studio 2010 Uninstall Utility on MSDN Microsoft site, but it only works if I remove SP1. When I've read instraction about uinstalling SP1 I discovered that (I quote note from Microsoft site) "
If you installed SP1 yourself, you can uninstall it. However, if your computer came with SP1 already installed, it can't be uninstalled."
And we just got new computers with SP1 preinstalled. So, I can not uninstall C++ 2010 and I can not uninstall SP1 in order to install Revit 2012.
Is there really one option left - to reinstall Windows 7?
