Installation & Licensing
Revit Architecture 2012 Problem Installing
2 REPLIES 2
maddie.dawson
138 Views, 2 Replies
Hi there,
I've just been through the installation process for Revit Architecture 2012. In the end however, (before it did much installing at all), it said that all the items failed to install. I'm not sure what to do? I've turned the computer on and off etc. But it still won't work. How do I get the installation to work?
2 REPLIES 2
TravisNave
in reply to: maddie.dawson
Post the installation log file on the failure screen.  I suspect it's a prerequisite that failed.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
maddie.dawson
in reply to: TravisNave
Oh, I just figured it out. Thank you anyway!
Administrator Productivity
