Installation & Licensing
New Member
Message 1 of 18 (2,492 Views)
Accepted Solution
*Revit Architecture 2012 Installation Problems
2492 Views, 17 Replies
03-22-2012 01:26 PM
I ran the installation that I downloaded from the Students part of the site. The install goes as far as putting in the product code, after that it gives an error. (refer to the attachments)
Someone help me out? I can give my computer specs and other things, just reply.
*Expert Elite*
TravisNave
Message 2 of 18 (2,489 Views)
Re: *Revit Architecture 2012 Installation Problems
03-22-2012 01:28 PM in reply to: ccarpenterhchs
Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
You need to uninstall your Visual C++ from Control Panel > Programs and then run your installer again.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
New Member
Message 3 of 18 (2,262 Views)
05-19-2012 11:14 PM in reply to: ccarpenterhchs
thanx alot sorry do i have to uninstall all c++?
*Expert Elite*
TravisNave
Message 4 of 18 (2,249 Views)
05-21-2012 07:41 AM in reply to: fzunit
Start with just the 2010 versions.  If you get failures for others, then do the same.  You should be fine as this is a common issue.  The Autodesk installer and Windows Update will put back the versions after you remove them, so there's not a lot ot be worried about.
Member
10779706
Message 5 of 18 (2,057 Views)
08-27-2012 08:28 PM in reply to: ccarpenterhchs
i have uninstalled almost all of my visual c++ programs and i am still having problems with my install of revit architecture 2012. what should be the next step because i am a student and my school just upgraded and i need the program up and running asap. i am attatching my log file to help with diagnostics. thank you for your time and assistance and hope to hear from you soon.
*Expert Elite*
TravisNave
Message 6 of 18 (2,021 Views)
08-28-2012 08:25 AM in reply to: 10779706
Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
Make sure you don't have any C++ 2005.  If it still fails, seeif you can perform the necessary update manually from Microsoft before you install.
Member
10779706
Message 7 of 18 (2,015 Views)
08-28-2012 10:47 AM in reply to: ccarpenterhchs
i manually installed from windows update and windows update keeps asking to download the same file over and over. i have tried removing all of my c++ 05, 08, & 10 seperately and all together and i am still having the same results. i am restarting between uninstallations/installations of c++ and nothing still getting error code 1603 for Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) but i have it downloaded several times (see attatchments).
Member
10779706
Message 8 of 18 (2,012 Views)
08-28-2012 10:51 AM in reply to: 10779706
*Expert Elite*
TravisNave
Message 9 of 18 (2,008 Views)
08-28-2012 11:01 AM in reply to: 10779706
Okay, well remove all the 2005 instances and do not replace them.  Run the Autodesk installer and let it install the versions it wants.
Member
Message 10 of 18 (1,278 Views)
06-18-2013 08:23 PM in reply to: TravisNave
Can you possibly help with my problem upon opening the install file it gets to the end and says some files can not be created and says to close all application and restart my computer i do this and start again and it says the same thing
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
