Installation & Licensing
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
*Revit Architectu re 2012 Installati on Problems
- Highlight
- Email to a Friend
I ran the installation that I downloaded from the Students part of the site. The install goes as far as putting in the product code, after that it gives an error. (refer to the attachments)
Someone help me out? I can give my computer specs and other things, just reply.
Re: *Revit Architectu re 2012 Installati on Problems
- Highlight
- Email to a Friend
Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
You need to uninstall your Visual C++ from Control Panel > Programs and then run your installer again.
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: *Revit Architectu re 2012 Installati on Problems
- Highlight
- Email to a Friend
thanx alot sorry do i have to uninstall all c++?
- Highlight
- Email to a Friend
Start with just the 2010 versions. If you get failures for others, then do the same. You should be fine as this is a common issue. The Autodesk installer and Windows Update will put back the versions after you remove them, so there's not a lot ot be worried about.
- Highlight
- Email to a Friend
i have uninstalled almost all of my visual c++ programs and i am still having problems with my install of revit architecture 2012. what should be the next step because i am a student and my school just upgraded and i need the program up and running asap. i am attatching my log file to help with diagnostics. thank you for your time and assistance and hope to hear from you soon.
- Highlight
- Email to a Friend
Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
Make sure you don't have any C++ 2005. If it still fails, seeif you can perform the necessary update manually from Microsoft before you install.
- Highlight
- Email to a Friend
i manually installed from windows update and windows update keeps asking to download the same file over and over. i have tried removing all of my c++ 05, 08, & 10 seperately and all together and i am still having the same results. i am restarting between uninstallations/installations of c++ and nothing still getting error code 1603 for Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) but i have it downloaded several times (see attatchments).
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
Okay, well remove all the 2005 instances and do not replace them. Run the Autodesk installer and let it install the versions it wants.
