Revit is not finishing the installation. See log file
2012/1/13:18:18:27 Janž JANŽ-PC === Setup started on JANŽ-PC by Janž ===
2012/1/13:18:18:27 Janž JANŽ-PC Launch
2012/1/13:18:20:07 Janž JANŽ-PC === Setup ended ===
2012/1/13:18:18:29 Janž JANŽ-PC === Setup started on JANŽ-PC by Janž ===
2012/1/13:18:18:29 Janž JANŽ-PC Launch
2012/1/13:18:20:09 Janž JANŽ-PC PageOpen LaunchDialog
2012/1/13:18:21:01 Janž JANŽ-PC PageOpen LicenseDialog
2012/1/13:18:21:46 Janž JANŽ-PC PageOpen ProductInfoDialog
2012/1/13:18:22:23 Janž JANŽ-PC PageOpen ProductSelectionDialog2
2012/1/13:18:22:47 Janž JANŽ-PC PageOpen FullProgressDialog
2012/1/13:18:22:47 Janž JANŽ-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Users\Janž\Downloads\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\JAN~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2012/1/13:18:22:54 Janž JANŽ-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
2012/1/13:18:22:55 Janž JANŽ-PC PageOpen InstallCompleteDialog
2012/1/13:18:25:40 Janž JANŽ-PC === Setup ended ===
2012/1/13:20:20:22 Janž JANŽ-PC === Setup started on JANŽ-PC by Janž ===
2012/1/13:20:20:22 Janž JANŽ-PC Launch
2012/1/13:20:21:42 Janž JANŽ-PC === Setup ended ===
2012/1/13:20:20:24 Janž JANŽ-PC === Setup started on JANŽ-PC by Janž ===
2012/1/13:20:20:24 Janž JANŽ-PC Launch
2012/1/13:20:21:42 Janž JANŽ-PC PageOpen LaunchDialog
2012/1/13:20:22:40 Janž JANŽ-PC PageOpen LicenseDialog
2012/1/13:20:23:34 Janž JANŽ-PC PageOpen ProductInfoDialog
2012/1/13:20:24:08 Janž JANŽ-PC PageOpen ProductSelectionDialog2
2012/1/13:20:24:15 Janž JANŽ-PC PageOpen FullProgressDialog
2012/1/13:20:24:16 Janž JANŽ-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Users\Janž\Downloads\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\JAN~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2012/1/13:20:25:17 Janž JANŽ-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
2012/1/13:20:25:18 Janž JANŽ-PC PageOpen InstallCompleteDialog
2012/1/13:20:26:08 Janž JANŽ-PC === Setup ended ===
2012/1/15:23:22:56 Janž JANŽ-PC === Setup started on JANŽ-PC by Janž ===
2012/1/15:23:22:56 Janž JANŽ-PC Launch
2012/1/15:23:24:34 Janž JANŽ-PC === Setup ended ===
2012/1/15:23:22:57 Janž JANŽ-PC === Setup started on JANŽ-PC by Janž ===
2012/1/15:23:22:57 Janž JANŽ-PC Launch
2012/1/15:23:24:35 Janž JANŽ-PC PageOpen LaunchDialog
2012/1/15:23:25:25 Janž JANŽ-PC PageOpen LicenseDialog
2012/1/15:23:25:51 Janž JANŽ-PC PageOpen ProductInfoDialog
2012/1/15:23:25:59 Janž JANŽ-PC PageOpen ProductSelectionDialog2
2012/1/15:23:26:16 Janž JANŽ-PC PageOpen FullProgressDialog
2012/1/15:23:26:16 Janž JANŽ-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Users\Janž\Downloads\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\JAN~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2012/1/15:23:31:58 Janž JANŽ-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
2012/1/15:23:31:59 Janž JANŽ-PC PageOpen InstallCompleteDialog
2012/1/15:23:32:06 Janž JANŽ-PC === Setup ended ===
2012/1/16:01:18:46 Janž JANŽ-PC === Setup started on JANŽ-PC by Janž ===
2012/1/16:01:18:46 Janž JANŽ-PC Launch
2012/1/16:01:20:00 Janž JANŽ-PC === Setup ended ===
2012/1/16:01:18:47 Janž JANŽ-PC === Setup started on JANŽ-PC by Janž ===
2012/1/16:01:18:47 Janž JANŽ-PC Launch
2012/1/16:01:20:00 Janž JANŽ-PC PageOpen LaunchDialog
2012/1/16:01:23:02 Janž JANŽ-PC PageOpen LicenseDialog
2012/1/16:01:30:39 Janž JANŽ-PC PageOpen ProductInfoDialog
2012/1/16:01:30:45 Janž JANŽ-PC PageOpen ProductSelectionDialog2
2012/1/16:01:31:02 Janž JANŽ-PC PageOpen FullProgressDialog
2012/1/16:01:31:02 Janž JANŽ-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Users\Janž\Downloads\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\JAN~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2012/1/16:01:31:09 Janž JANŽ-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
Please try
http://forums.autodesk.com/t5/Installation-Licensing/Revit-MEP-2011-cannot-be-installed/m-p/
Revit Architecture 2012 Error 1606
Log file:
2012/2/24:11:44:40 YZF YZF-NB === Setup started on YZF-NB by YZF ===
2012/2/24:11:44:40 YZF YZF-NB Launch
2012/2/24:11:45:09 YZF YZF-NB === Setup ended ===
2012/2/24:11:45:10 YZF YZF-NB PageOpen LaunchDialog
2012/2/24:11:46:34 YZF YZF-NB PageOpen LicenseDialog
2012/2/24:11:46:46 YZF YZF-NB PageOpen ProductInfoDialog
2012/2/24:11:47:18 YZF YZF-NB PageOpen ProductSelectionDialog2
2012/2/24:11:47:35 YZF YZF-NB PageOpen FullProgressDialog
2012/2/24:11:47:35 YZF YZF-NB Installing Autodesk® Design Review 2012: TRANSFORMS="C:\Users\YZF\AppData\Local\Temp\_AI4578.tmp\x86\en-us\Components\adr2012\SetupDesignReview2012-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\Cad 2012\" INSTALLDIR="C:\Program Files\Autodesk\Autodesk Design Review 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/2/24:11:48:41 YZF YZF-NB Install Autodesk® Design Review 2012 Succeeded
2012/2/24:11:48:41 YZF YZF-NB Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\Cad 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/2/24:11:48:50 YZF YZF-NB Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2012/2/24:11:48:50 YZF YZF-NB Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\Cad 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/2/24:11:49:02 YZF YZF-NB Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2012/2/24:11:49:02 YZF YZF-NB Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\Cad 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/2/24:11:49:11 YZF YZF-NB Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2012/2/24:11:49:11 YZF YZF-NB Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\Cad 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/2/24:11:49:19 YZF YZF-NB Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2012/2/24:11:49:19 YZF YZF-NB Installing DirectX® Runtime: D:\Cad 2012\3rdParty\DirectX\DXSETUP.exe /silent
2012/2/24:11:50:18 YZF YZF-NB Install DirectX® Runtime Succeeded
2012/2/24:11:50:18 YZF YZF-NB Installing VSTA aide: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\Cad 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/2/24:11:52:41 YZF YZF-NB Install VSTA aide Succeeded
2012/2/24:11:52:41 YZF YZF-NB Installing VSTA art: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\Cad 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/2/24:11:52:46 YZF YZF-NB Install VSTA art Succeeded
2012/2/24:11:52:49 YZF YZF-NB Installing Autodesk® Revit® Architecture 2012: TRANSFORMS="D:\Cad 2012\x86\en-us\RAC2012\RAC2012.mst;C:\Users\YZF\AppData\Local\Temp\_AI4578.tmp\x86\RAC2012\RAC2012-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\Cad 2012\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/2/24:12:34:48 YZF YZF-NB Install Autodesk® Revit® Architecture 2012 Succeeded
2012/2/24:12:34:49 YZF YZF-NB Installing Autodesk® Revit® Architecture 2012 Language Pack: TRANSFORMS="C:\Users\YZF\AppData\Local\Temp\_AI4578.tmp\_la2F73.tmp.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\Cad 2012\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/2/24:12:34:52 YZF YZF-NB Install Autodesk® Revit® Architecture 2012 Language Pack Succeeded
2012/2/24:12:34:52 YZF YZF-NB Installing Autodesk Material Library 2012 - Low Image Library: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\Cad 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/2/24:12:35:18 YZF YZF-NB Install Autodesk Material Library 2012 - Low Image Library Failed Installation aborted, Result=1603
2012/2/24:12:35:19 YZF YZF-NB Rollback Autodesk® Revit® Architecture 2012 Language Pack Failed Installation aborted, Result=1603
2012/2/24:12:36:53 YZF YZF-NB Rollback Autodesk® Revit® Architecture 2012 Succeeded
2012/2/24:12:36:57 YZF YZF-NB Rollback VSTA art Succeeded
2012/2/24:12:37:52 YZF YZF-NB Rollback VSTA aide Succeeded
2012/2/24:12:37:52 YZF YZF-NB Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2012/2/24:12:37:56 YZF YZF-NB Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2012/2/24:12:38:01 YZF YZF-NB Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2012/2/24:12:38:05 YZF YZF-NB Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2012/2/24:12:38:08 YZF YZF-NB Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2012/2/24:12:38:29 YZF YZF-NB Rollback Autodesk® Design Review 2012 Succeeded
I have tried the solutions found in the links, none of these worked.
I have installed both the (86) and (64) versions of all three C++ redistribute and SP1 as well with no luck.
I shut every task, and every process I could shut down, down and still it will not install.
The strange thing is that there is one existing copy of ADT 2012 up and running on this WS just fine, I just cannot get the BDS Premium to install the remaining programs.
Any help would be apriciated.
Try uninstalling all of your Visual C++ Redistributables instead. That is usually the culprit. The Autodesk installer will reinstall the versions it needs, then you can update them afterwards if necessary.
I did try that with no luck as well as uninstalling all of the C++ programs, also this did not work.
Thank you.
