• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    Revit Architecture 2012 _ Default Template File Invalid
    196 Views, 0 Replies
    02-15-2013 12:00 PM
    i have a problem when i start to use Revit.
    Default Template File Invalid:
    the default template file you have specified does not exist:
    to change the default file path, from the Application menu select Options, and then the File Locations tab.
    what can i do??
    thank you!
    Please use plain text.
