I have been scouring this website for help, but can't seem to find anything relevant to installing revit 2015 onto windows 8.
I get the following error
2014/4/22:11:18:36 Louise LOUISELAPTOP Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2014/4/22:11:18:36 Louise LOUISELAPTOP Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
I have tried uninstalling and re-installing x64 and x86 and restarting the laptop, but then I have also found somewhere that it says that C++ 2012 doesn't work on windows 8?
I'm a little bit comfused, could anyone lend a hand?
Many people are having this issue lately. It's a failed download. I have started putting it in my hot issues in my signature line as a result.
Install Autodesk® Revit® 2015 Language Pack Failed Download Failed, Installation aborted, Result=1603
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Good Luck!
I've sorted it, basically instead I downloaded the file and then installed it and it worked, no idea why!
Thanks everyone
Everytime I try to instal Student Copy of Revit 2016 I see this error message.
Windows ® Installer. V 5.0.7601.17514
msiexec /Option <Required Parameter> [Optional Parameter]
Install Options
</package | /i> <Product.msi>
Installs or configures a product
/a <Product.msi>
Administrative install - Installs a product on the network
/j<u|m> <Product.msi> [/t <Transform List>] [/g <Language ID>]
Advertises a product - m to all users, u to current user
</uninstall | /x> <Product.msi | ProductCode>
Uninstalls the product
Display Options
/quiet
Quiet mode, no user interaction
/passive
Unattended mode - progress bar only
/q[n|b|r|f]
Sets user interface level
n - No UI
b - Basic UI
r - Reduced UI
f - Full UI (default)
/help
Help information
Restart Options
/norestart
Do not restart after the installation is complete
/promptrestart
Prompts the user for restart if necessary
/forcerestart
Always restart the computer after installation
Logging Options
/l[i|w|e|a|r|u|c|m|o|p|v|x|+|!|*] <LogFile>
i - Status messages
w - Nonfatal warnings
e - All error messages
a - Start up of actions
r - Action-specific records
u - User requests
c - Initial UI parameters
m - Out-of-memory or fatal exit information
o - Out-of-disk-space messages
p - Terminal properties
v - Verbose output
x - Extra debugging information
+ - Append to existing log file
! - Flush each line to the log
* - Log all information, except for v and x options
/log <LogFile>
Equivalent of /l* <LogFile>
Update Options
/update <Update1.msp>[;Update2.msp]
Applies update(s)
/uninstall <PatchCodeGuid>[;Update2.msp] /package <Product.msi | ProductCode>
Remove update(s) for a product
Repair Options
/f[p|e|c|m|s|o|d|a|u|v] <Product.msi | ProductCode>
Repairs a product
p - only if file is missing
o - if file is missing or an older version is installed (default)
e - if file is missing or an equal or older version is installed
d - if file is missing or a different version is installed
c - if file is missing or checksum does not match the calculated value
a - forces all files to be reinstalled
u - all required user-specific registry entries (default)
m - all required computer-specific registry entries (default)
s - all existing shortcuts (default)
v - runs from source and recaches local package
Setting Public Properties
[PROPERTY=PropertyValue]
Consult the Windows ® Installer SDK for additional documentation on the
command line syntax.
Copyright © Microsoft Corporation. All rights reserved.
Portions of this software are based in part on the work of the Independent JPEG Group.
If you havent tried this yet, just encountered the same today, thanks to Chris(IT support), he rejoined the user to the domain. Somehow it affected the profile and so the installation was successful. Hope this would also be your solution too. Thanks.
Cheers,
Ellyn Centenera
TCI- AE
First go to control panel>Programs and Features>Turn Window features on or off>
select to turn on .NET Framework 3.5 (includes .NET 2.0 and 3.0), you have to be connected to the internet to download this feature.
Back to Uninstall or change a program:
I also have uninstalled only the latest Microsoft Visual C++ you may find 2005/2008/2012, please check the dates they were installed.
Restart. I have encountered some missing dlls when the PC turned on, but you may not encounter this, if you did, as you run the Autodesk installer again it will fix those errors anyway.
The installer should then proceed and finish successfully.
