hi there,
i'm trying to install Revit 2014 on Windows 8 32-bit operating system, but unfortunatly i keep on getting this error!!
im not sure if Revit 2014 is supported with my operating system, but in case if its not what can i do :S
i really do need to install it 😞
would appreciate your help
Many Thanks
Aya Alhunaiti
Revit 2014 isn't supported on Windows 8 32-bit.
Danny
Hi @Anonymous & @Anonymous
Check out the System Requirements here... http://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles/System-Requirements-for-Autodesk-Revit-2014-Products.html
Also, please refer to the following Autodesk Knowledge Article here... http://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles/Operating-system-compatibility-for-Autodesk-Revit-products.html
Revit 2014 is available as a 32 Bit installer but is not supported on Windows 8.
As advised by others, consider x64 Bit and move away from x32.
I believe there may be a work around but you have to install .NET Framework (includes .NET 2.0 and 3.0) before you can install Revit.
Go to Control Panel --> Click on Uninstall or Change a program --> on the left click on Turn Windows features on or off.
This will install these features which will allow you to install Revit 2014, 2013 and 2012.
Duncan
