I have been try to install Revit 2014 on my laptop since last 3 days to no avail, due to my erratic internet connection, the installer download stops/aborts in between every time, can someone please take me through the manual installation process where i can first download the fils and then install the software ??
Thankyou !
Solved by TravisNave. Go to Solution.
Yes, I would recommend that you try fully downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
thankyou, i downloaded and installed the programme, but there are no families included in the installation, do you know where i could download those?
