Installation & Licensing
Revit 2014 load error on first startup after install on windows 8.1
1 REPLY 1
brad.marmion
232 Views, 1 Reply
Hi Autdesk Community
I have tried installing revit 2014 a number of times and it sucessfully installs but will not load, see screenshot of error attached. in response to the error reort feedback i have installed updates 1, but when i try to install update 2 it does not recognise that revit 2014 is installed.
As an additional note before upgrading to windows 8.1 i had revit 2013 woring on the computer, but uninstaaled it in an attempt to do a fresh install of revit 2014, but now i cant install revit 2013 or 2014.
If relavant i have navisworks and mudbox succesffully working on the computer
Can you provide any help with this?
Thanks Brad
1 REPLY 1
dembkod
in reply to: brad.marmion
brad.marmion
You have a corrupt install. I would uninstall what you have and then reinstall and include the Service pack at that point. In the installer, when you check the box to install Revit, click the Drop-down arrow beneath the box to open the configuration options.
There should be an area to include the service pack on install.
Thank you for taking part in our community!
David Dembkoski
Administrator Productivity
