Installation & Licensing
Revit 2014 installation 1402 error
2 REPLIES 2
m.brinkerink
889 Views, 2 Replies
I've tried to install Revit 2014 (as part of Building design suite) 3 times now but the installations have failed every time.
I seemes to be installed completelly but in the end it says that the installation doesn't have the rights to alter some registry key (?\ROOLEAXCtrl.1\CLSID).
I have total admin rights on this workstation so I should be able to edit any registry key .
I have disabled the virusscanner but this hasn't altred the situation.
Could anyone please help?
2 REPLIES 2
My first suggestion would be to try the solution outlined in the following technical solution.  While your windows user account is part of the administrators group, it is possible to have restricted privileges to certain areas of the registry and these steps should help to resolve this issue.
Tony Michniewicz
Autodesk Revit QA
Tony Michniewicz
Revit Software QA Analyst
Thank you very much,
The resetting of the rights in the registry solved this problem.
It is strange that the instalation of Revit 2012 and 2013 weren't affected by a lack of rights. Those installations were however 1 and 2 years and a lot of Windows updates ago.
Thanks for the quick solution.
Administrator Productivity
