Installation & Licensing
Member
m.brinkerink
Message 1 of 3 (589 Views)
Revit 2014 installation 1402 error
589 Views, 2 Replies
06-21-2013 12:10 AM
I've tried to install Revit 2014 (as part of Building design suite) 3 times now but the installations have failed every time.
I seemes to be installed completelly but in the end it says that the installation doesn't have the rights to alter some registry key (?\ROOLEAXCtrl.1\CLSID).
I have total admin rights on this workstation so I should be able to edit any registry key .
I have disabled the virusscanner but this hasn't altred the situation.
Could anyone please help?
Employee
tony.michniewicz
Message 2 of 3 (575 Views)
Re: Revit 2014 installation 1402 error
06-21-2013 05:50 AM in reply to: m.brinkerink
My first suggestion would be to try the solution outlined in the following technical solution.  While your windows user account is part of the administrators group, it is possible to have restricted privileges to certain areas of the registry and these steps should help to resolve this issue.
Tony Michniewicz
Autodesk Revit QA
Member
m.brinkerink
Message 3 of 3 (545 Views)
06-24-2013 03:14 AM in reply to: tony.michniewicz
Thank you very much,
The resetting of the rights in the registry solved this problem.
It is strange that the instalation of Revit 2012 and 2013 weren't affected by a lack of rights. Those installations were however 1 and 2 years and a lot of Windows updates ago.
Thanks for the quick solution.
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
