Installation & Licensing
coopert
Message 1 of 12 (1,071 Views)
Revit 2014 Structure not holding templates or family template path
1071 Views, 11 Replies
09-26-2013 05:44 AM
I have tried two installs for 2014 for the Plant 3d Premium suite which includes Revit Structure.
We have installs of 2013 with no issues.  The revit.ini file is setup after an initial install and modified to place paths onto our network.
The new installs do not hold the templates or the family template path.  I modify them (which I shouldn't have to do because they are set in the revit.ini file), close the program, reopen and they are cleared again.
Any ideas?
Product Support
david.lau
Message 2 of 12 (1,063 Views)
Re: Revit 2014 Structure not holding templates or family template path
09-26-2013 05:55 AM in reply to: coopert
You can modify the revit.ini file and then include in the Deployment.  There are a couple of entries in Wikihelp but it is a bit finicky right now.
This video is pretty good for setting up the custom Revit.ini.
http://www.youtube.com/watch?v=jqvYFnt3iqQ
I hope this helps.
David Lau
coopert
Message 3 of 12 (1,054 Views)
09-26-2013 06:31 AM in reply to: david.lau
My revit.ini file has the paths included in the deployment.
I have succesfully done this for 2013, but 2014 doesn;t hold the paths.
Regardless, why are they not holding if I modify them after the fact?
Product Support
david.lau
Message 4 of 12 (1,040 Views)
09-26-2013 10:54 AM in reply to: coopert
Did you edit the Revit.ini file located here?
C:\ProgramData\Autodesk\RVT 2014\UserDataCache
David Lau
coopert
Message 5 of 12 (1,030 Views)
09-26-2013 11:29 AM in reply to: david.lau
No.  Didn't have to in 2013.
I looked at it.  The file is empty.
There is a file called
Revit.ini.gen  that conatinas the proper file paths and information.
coopert
Message 6 of 12 (1,000 Views)
09-27-2013 10:36 AM in reply to: coopert
Should I copy the information from the revit.ini.gen file into the revit.ini file?
Will it retain the information in the ini file then?
Product Support
david.lau
Message 7 of 12 (991 Views)
09-27-2013 11:06 AM in reply to: coopert
coopert
Message 8 of 12 (986 Views)
09-27-2013 11:44 AM in reply to: david.lau
Whoa,
Something is messed up with the revit structure file.
I changed the revit.ini file in the userdatacache directory and it did not update the file in the username/appdata/... location.  I had to enter the file locations in there.
Think the program has a an issue there.
Product Support
david.lau
Message 9 of 12 (981 Views)
09-27-2013 12:01 PM in reply to: coopert
Use a broswer download of the installer via our Virtual Agent (#3):
http://upandready.typepad.com/up_and_ready/2013/01/quick-start-downloads.html
David Lau
coopert
Message 10 of 12 (978 Views)
09-27-2013 12:03 PM in reply to: david.lau
I'll look at it, but we have the deployments all built for installs of Plant3d Premium and Building Design.
I may just modify the ini files manually.
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
