Installation & Licensing
Revit 2014 Service Pack 1
3 REPLIES 3
2411 Views, 3 Replies
I tried to find this file on my computer but it is missing... I have Revit 2014 - student version. This is the link from where I dowloaded the service pack http://usa.autodesk.com/adsk/servlet/...
But I can't find if I had installed the First Customer Ship build of Autodesk Revit 2014 (Build: 20130308_1515).
3 REPLIES 3
TravisNave
Welcome to the community.  The update is looking for your original installation files.  If you deleted it or did not save it, then you can redownload it again, or you can download the trial, or use Matt, the virtual assistant to get it.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21889745&linkID=9240617
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
a01175228
in reply to: TravisNave
this is for Autocadnot Revit. Could give he right link please
TravisNave
in reply to: a01175228
Autodesk changed their support links.  Hopefully I can get updated links as customers like you point them out.  Thanks!
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Autodesk Forums:
Administrator Productivity
