Installation & Licensing
New Member
Message 1 of 7 (432 Views)
Revit 2013 wont open !!!
432 Views, 6 Replies
10-20-2012 05:52 AM
i just installed revit 2013, but everytime i try to open it, it just doesnt open. please i really need help
Employee
Message 2 of 7 (392 Views)
Re: Revit 2013 wont open !!!
10-22-2012 06:25 AM in reply to: yabuwardeh
Are you seeing any error messages or a triangle with an exclamation point?
Try using the Repair option from the Control Panel > Programs and Features.
Also, if you're on Win7, when launching, use the right click > Run as Administrator.
Feel free to send more details so we can see what is happening.
Thanks.
Cheers,
Alison
___________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Alison Gangler
IPG - ICP Install Engineer
Autodesk, Inc.
Member
Message 3 of 7 (386 Views)
10-22-2012 10:54 AM in reply to: alison.gangler
The Run as Admin worked for me too! I've been trying to find a solution for a while, and you nailed it. How do I make it so that I don't always have to tell it to do that?
Employee
Message 4 of 7 (383 Views)
10-22-2012 11:19 AM in reply to: steveterhune
You can easily set the shortcut for Revit to launch always as Run as Administrator. Select the shortcut from the desktop or Start Menu > All Programs. Then right click on the shortcut, select Properties.
Then in the shortcut properties, select the Compatability tab. At the bottom of this tab, you will see the option to Run the program as an Administrator under the Privilege Level section. I'm attaching a screen shot for you.
RunAsAdmin
Cheers,
Alison
Alison Gangler
Autodesk, Inc.
Member
Message 5 of 7 (382 Views)
10-22-2012 11:24 AM in reply to: alison.gangler
You're great Allison! Thx. I wonder why I have never had to deal with this in the past.
New Member
Message 6 of 7 (371 Views)
10-22-2012 03:14 PM in reply to: yabuwardeh
Hey
No my problem is that everytime i click on revit, only the small running page appeared, and i also tried to uninstall it, it didnt work either  :smileysad:, do you know what can i do to solve it.
Thank you
New Member
Message 7 of 7 (307 Views)
11-24-2012 05:42 AM in reply to: yabuwardeh
Hi Alison
I have the same problem with Revit. Have Uninstalled and Installed again twice and always when I open it closes suddenly without any warn. Have followed the steps informed before and it didn´t work.
I have installed 3Dmax 2013 and Autocad 2013 too, and the process to install is the same and both are working
What more do I have to do?
Thanks for your attention
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
