• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Contributor don
    don
    Re: Revit 2013, no Templates or Libraries installed
    10-01-2012 01:18 PM in reply to: kheaver
    best advice, thank you, took 3 passes the rfa's appeared on pass #2, the rte's finally arrived on pass #3.  now the only problem is that I installed from a download to my download directory and it sits there.  so, is it safe to delete, did it install everything it needed to everywhere else, or is it a doppelganger for life, permanently resident in the downloads of life?
    Please use plain text.
    Active Member
    fayoud
    Re : Revit 2013, no Templates or Libraries installed
    10-21-2012 04:11 PM in reply to: kheaver
    you will find what you need in my blog and after all what you need to do is to extract the files in the correct paths
    http://faycaloudjhih.blogspot.com/2012/08/revit-structure-templates-families.html
    Good Luck
    Oudjhih Fayçal
    New Member
    01-28-2013 09:51 AM in reply to: kheaver
    It woks Thank you
