• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    Revit 2013 install on MS Hyper-V server...
    120 Views, 1 Replies
    11-12-2012 04:43 PM
    We're a small office with 2 subscription standalone Revit licenses.  We have a Hyper-V enabled server, which allows us to run our accounting and other processes remotely.  It would be really nice to run our Revit the same way.  We would have to switch to a network license, but we haven't been able to find any other information about doing the installation.  Our reseller spun their wheels for a long time and came back with a very non-committal response, which didn't justify any expense on our part to implement.  Does anyone have any experience with this?
    We aren't IT pros (it is a small office) but we have invested in robust infrastructure, so the network backbone in office should support us.
    Any advice?
    Thanks!
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: Revit 2013 install on MS Hyper-V server...
    11-13-2012 02:15 PM in reply to: KristineWoolsey6183
    Your reseller balked because this kind of setup is not supported.  It states so clearly in the EULA.  However, there is a Citrix provided solution that is supported:
    http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=13959101
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
