Installation & Licensing
Revit 2013 install error " Communication Failure"
3 REPLIES 3
513 Views, 3 Replies
I downloaded the student version to my windows 8 and when I try to install it it says " communication failure"  I turned off all my security walls and firewall and also I have a mail client signed in. But I dont know still what the problem is.
3 REPLIES 3
TravisNave
Welcome to the forums!
Revit 2013 is not supported on Windows 8.  You can probably get the student version of 2014 though.
Autodesk Forums:
Thanks for the reply but actually it turns out that It Revit 2013 is compatible with windows 8 but the reason was; I moved the setupp file from the original location where I downloaded to from autodesk website. i downloaded the setup again and didnt move it, and it turned out just fine! such small mistakes can take your 2 weeks to figure it out!
TravisNave
Thanks for the follow-up.  However, Revit 2013 is not supported on Windows 8.  I am glad that you got it working though.  Thanks for sharing.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19048377&linkID=9240617
Autodesk Forums:
Administrator Productivity
