i have been repeatadly getting this error after trying to install with this installation file log. whats wrong?! i also addded an attachment not sure the proper way of posting a log.
2014/1/18:21:25:36 Tony TONY === Setup started on TONY by Tony === 2014/1/18:21:25:36 Tony TONY Launch 2014/1/18:21:25:36 Tony TONY CommandLine /url "http://trial2.autodesk.com/SWDLDDLM/2013/RVT/WI/Autodesk_Revit_2013_English_Win_32_64bit_wi_en-US_Se..." /SN 900-44358982 /PK 829E1 /student /akamai /auth authparam /sid SESSION_ID 2014/1/18:21:25:39 Tony TONY === Setup ended ===
2014/1/18:21:25:38 Tony TONY === Setup started on TONY by Tony === 2014/1/18:21:25:38 Tony TONY Launch 2014/1/18:21:25:38 Tony TONY Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/SETUP_x64.tar... 2014/1/18:21:25:39 Tony TONY PageOpen LaunchDialog 2014/1/18:21:26:40 Tony TONY PageOpen LicenseDialog 2014/1/18:21:51:02 Tony TONY PageOpen ProductInfoDialog 2014/1/18:21:51:02 Tony TONY PageOpen ProductSelectionDialog2 2014/1/18:21:51:09 Tony TONY PageOpen FullProgressDialog 2014/1/18:21:51:09 Tony TONY Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/DIRECTX.tar.l... 2014/1/18:21:51:09 Tony TONY Installing DirectX® Runtime: C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\DirectX\DXSETUP.exe /silent 2014/1/18:21:52:13 Tony TONY Install DirectX® Runtime Succeeded 2014/1/18:21:52:13 Tony TONY Download Skipped FaroSDK http://trial2.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/FaroSDK.tar.l... 2014/1/18:21:52:13 Tony TONY Installing FaroSDK: C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT /NORESTART /LOG="C:\Users\Tony\AppData\Local\Temp\FaroSDK.log" 2014/1/18:21:52:22 Tony TONY Install FaroSDK Succeeded 2014/1/18:21:52:22 Tony TONY Download Skipped RVT2013 http://trial2.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT2013_x64.t... 2014/1/18:21:52:22 Tony TONY Installing Autodesk® Revit® 2013: TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2013\x64\en-us\RVT2013\RVT2013.mst;C:\Users\Tony\AppData\Local\Temp\_AIA54C.tmp\x64\RVT2013\RVT2013-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/1/18:22:52:09 Tony TONY Install Autodesk® Revit® 2013 Succeeded 2014/1/18:22:52:10 Tony TONY Download Play RVT2013_en-us http://trial2.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT2013_x64_e... 2014/1/18:22:52:56 Tony TONY Download Aborted RVT2013_en-us http://trial2.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT2013_x64_e... 2014/1/18:22:52:56 Tony TONY Install Autodesk® Revit® 2013 Language Pack Failed Download Failed, Installation aborted, Result=1603 2014/1/18:22:57:27 Tony TONY Rollback Autodesk® Revit® 2013 Succeeded 2014/1/18:22:57:27 Tony TONY Rollback FaroSDK Failed Failure is ignored, Result=1619 2014/1/18:22:57:27 Tony TONY Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2014/1/18:22:57:27 Tony TONY PageOpen InstallCompleteDialog 2014/1/18:23:25:41 Tony TONY === Setup ended ===
2014/1/18:23:27:35 Tony TONY === Setup started on TONY by Tony === 2014/1/18:23:27:35 Tony TONY Launch 2014/1/18:23:27:35 Tony TONY CommandLine /url "http://trial2.autodesk.com/SWDLDDLM/2013/RVT/WI/Autodesk_Revit_2013_English_Win_32_64bit_wi_en-US_Se..." /SN 900-44358982 /PK 829E1 /student /akamai /auth authparam /sid SESSION_ID 2014/1/18:23:27:37 Tony TONY === Setup ended ===
2014/1/18:23:27:35 Tony TONY === Setup started on TONY by Tony === 2014/1/18:23:27:35 Tony TONY Launch 2014/1/18:23:27:36 Tony TONY Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/SETUP_x64.tar... 2014/1/18:23:27:37 Tony TONY PageOpen LaunchDialog 2014/1/18:23:28:17 Tony TONY PageOpen LicenseDialog 2014/1/18:23:28:20 Tony TONY PageOpen ProductInfoDialog 2014/1/18:23:28:20 Tony TONY PageOpen ProductSelectionDialog2 2014/1/18:23:28:23 Tony TONY PageOpen FullProgressDialog 2014/1/18:23:28:24 Tony TONY Download Play VCREDIST2010SP1X86 http://trial2.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCREDIST2010S... 2014/1/18:23:28:39 Tony TONY Download Complete VCREDIST2010SP1X86 http://trial2.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCREDIST2010S... 2014/1/18:23:28:39 Tony TONY Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart 2014/1/18:23:28:47 Tony TONY Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded 2014/1/18:23:28:48 Tony TONY Download Play VCREDIST2010SP1X64 http://trial2.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCREDIST2010S... 2014/1/18:23:29:05 Tony TONY Download Complete VCREDIST2010SP1X64 http://trial2.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCREDIST2010S... 2014/1/18:23:29:05 Tony TONY Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart 2014/1/18:23:29:14 Tony TONY Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded 2014/1/18:23:29:14 Tony TONY Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/DIRECTX.tar.l... 2014/1/18:23:29:14 Tony TONY Installing DirectX® Runtime: C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\DirectX\DXSETUP.exe /silent 2014/1/18:23:29:59 Tony TONY Install DirectX® Runtime Succeeded 2014/1/18:23:30:00 Tony TONY Download Skipped FaroSDK http://trial2.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/FaroSDK.tar.l... 2014/1/18:23:30:00 Tony TONY Installing FaroSDK: C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT /NORESTART /LOG="C:\Users\Tony\AppData\Local\Temp\FaroSDK.log" 2014/1/18:23:30:05 Tony TONY Install FaroSDK Succeeded 2014/1/18:23:30:05 Tony TONY Download Skipped RVT2013 http://trial2.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT2013_x64.t... 2014/1/18:23:30:05 Tony TONY Installing Autodesk® Revit® 2013: TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2013\x64\en-us\RVT2013\RVT2013.mst;C:\Users\Tony\AppData\Local\Temp\_AI50C2.tmp\x64\RVT2013\RVT2013-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/1/19:00:34:34 Tony TONY Install Autodesk® Revit® 2013 Succeeded 2014/1/19:00:34:34 Tony TONY Download Play RVT2013_en-us http://trial2.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT2013_x64_e... 2014/1/19:00:35:34 Tony TONY Download Aborted RVT2013_en-us http://trial2.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT2013_x64_e... 2014/1/19:00:35:34 Tony TONY Install Autodesk® Revit® 2013 Language Pack Failed Download Failed, Installation aborted, Result=1603 2014/1/19:00:39:33 Tony TONY Rollback Autodesk® Revit® 2013 Succeeded 2014/1/19:00:39:33 Tony TONY Rollback FaroSDK Failed Failure is ignored, Result=1619 2014/1/19:00:39:33 Tony TONY Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2014/1/19:00:39:33 Tony TONY Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619 2014/1/19:00:39:33 Tony TONY Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
