Installation & Licensing
Revit 2013 Installation: texture library cannot be installed
2 REPLIES 2
1608 Views, 2 Replies
During my installation when it is almost done a message pops up that says "Texture libraries cannot be installed before the materials library. Please run the installer, "MaterialLibrary2013.msi" then try to install the texture libraries again."  I have run the msi installer and I have a materials library listed in program manager but it still gets the same error message and failed install again.  Is there a solution?
2 REPLIES 2
The answer to the Texture Library Error during Install is that it won't install on a Windows Vista OS.  I had to upgrade to Windows 7 - JAHLA
TravisNave
Thanks for sharing.  Vista is indeed unsupported for Autodesk 2013 products and newer.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
