Installation & Licensing
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Revit 2013 Failed
- Highlight
- Email to a Friend
- Report Inappropriate Content
Hello. I am a student and trying to install Revit (the free student version). I have tried multiple times and two things have happened. The first several times the install hung at 3 of 6 installing then the last few times it stops after 4, says it has been installed with errors and the install of Revit 2013 has failed. I have made sure there is enough room on my computer, I have preformed updates and cleaned my computer and nothing seems to be helping. I also tried donloading from the browser as well as onto the computer.
PLEASE HELP!!!!
Re: Revit 2013 Failed
- Highlight
- Email to a Friend
You need to provide the installation log.
And the software did not hang, so if you aborted it, you probably made it worse. Revit has to download addtional content from the Internet. Depending on your connection, this could take hours. So make sure you have a good Internet connection.
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: Revit 2013 Failed
- Highlight
- Email to a Friend
I have a fast internet connection and I only aborted after 8 hours of leaving it to install the first itme. I was trying different things to make sure it wasn't something with my computer but I have no idea what I am doing. I just tried this again and here is the installation log. Any help is greatly appreciated.
- Highlight
- Email to a Friend
Error 1618 means that it thinks another installation is already in progress. Aborting the install may have done this. Have you tried a simple reboot?
Sometimes Revit can take over 8 hours to install.
- Highlight
- Email to a Friend
OK, I have re-started my computer and started the download over. It is not saying fail now it is still on Installing 3 of 6 and has been in this spot for about an hour.
Jilana
- Highlight
- Email to a Friend
Good. It might take awhile so repost any new installation log if you have problems.
- Highlight
- Email to a Friend
OK, it is still installing. Thank you for your help. How long is a good amount of time to leave it before deciding it's not doing anything? I left it for 8 hours last night.
- Highlight
- Email to a Friend
At this point it has been 9.5 hours and nothing has happened. The installation is in the same spot. I will leave it overnight to see if anything else happens. If not I am not sure what to do next?
- Highlight
- Email to a Friend
I suggest you to check this solution, see if it's helpful for you.
__________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Emily Xu
AutodeskCare | Product Support
Autodesk, Inc.
- Highlight
- Email to a Friend
I left my computer for over 24 hours and nothing happened. I had abort and restart my computer. I tried to add the site to my Trusted sites and it will not allow me as it says it has to be a https:// site to be added to the list. Could this be the issue? I do not know how to change the settings?
