Hi guys,
I am trying to install Building Design premium Suite but the whole things fails during Revit Installation.
I have attached the log file but there is nothing in there that can specify why is this happening.
Tried uninstalling Microsoft C++ 64bit redistributible as some people mentioned that it worked for them since computer had higher version than the installer, thus creating problems.
This solution did not work for me.
Any idea?
Milos
Solved by DannyHubbard. Go to Solution.
Solved by Milos_Vajdic. Go to Solution.
To install it?
To uninstall it?
Control Panel > Programs and Features
sorry ment to unistall there multiple c++ there ones for 2005 2008 and 2010 which one should i unistall
You should uninstall which ever version is failing according to the installation log. It will tell you which one it failed on at the end of the log. Remove that version.
