Installation & Licensing
Revit 2013 Failed - Installation aborted, Result=1603
23 REPLIES 23
Message 1 of 24
Milos_Vajdic
24476 Views, 23 Replies
Hi guys,
I am trying to install Building Design premium Suite but the whole things fails during Revit Installation.
I have attached the log file but there is nothing in there that can specify why is this happening.
Tried uninstalling Microsoft C++ 64bit redistributible as some people mentioned that it worked for them since computer had higher version than the installer, thus creating problems.
This solution did not work for me.
Any idea?
Milos
23 REPLIES 23
Message 21 of 24
jsalaiz111
in reply to: Milos_Vajdic
how do you get to the files for microsoft visual c++
Message 22 of 24
TravisNave
in reply to: jsalaiz111
To install it?
http://support.microsoft.com
To uninstall it?
Control Panel > Programs and Features
Autodesk Forums:
Message 23 of 24
jsalaiz111
in reply to: TravisNave
sorry ment to unistall there multiple c++ there ones for 2005 2008 and 2010 which one should i unistall
Message 24 of 24
TravisNave
You should uninstall which ever version is failing according to the installation log.  It will tell you which one it failed on at the end of the log.  Remove that version.
Autodesk Forums:
Administrator Productivity
