• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    stevensm
    Revit 2013 Crashes at Splash Screen. Please Help!!
    567 Views, 2 Replies
    10-01-2012 09:30 PM
    I have done numerous clean uninstalls and reinstalled revit 2013 on windows seven numerous time over the oast couple of days. No matter what I've done I can only get to the point where the program downloads and installs and then crashes at the splash screen. I am using the student version as I am a student. I have attached the latest journal which isthe same as the previous ones. Please Help!! I have tried all kinds of things such as going into regedit and task manager.....
    Please use plain text.
    Product Support
    aaronhai
    Re: Revit 2013 Crashes at Splash Screen. Please Help!!
    10-02-2012 07:55 PM in reply to: stevensm
    Please see if this applies:
    http://wikihelp.autodesk.com/Revit/enu/Community/Troubleshooting/Revit_2012_Hangs_at_Splash_Screen_o...
    Aaron Hai
    AutodeskCare | Product Support
    TW | PI | YT | BLOG
    If my reply was helpful, please Kudo or Accept as Solution. :smileyhappy:
    New Member
    10-27-2012 08:33 PM in reply to: stevensm
    Hello, I was having a similar problem than yours but any of the methods you could find in forums was helping. I downloaded Revit 2013 from Student Autodesk and Installed it directly from the web, also got the 2 Update packages, and was stil having the same problem. How did I solve it? Well, I am not sure if this can be applicable to everyone but I realized I never even finished the license process for Revit, when it began to fail initializing, so I had to check out the License Transfer Utility that is the one that takes the serial and the ID directly from the download link as far as I know.
    After following those steps, Revit began working normally. Hope it hepls you, and once again I am not sure if this is a generic problem or just was in my case.
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18221949&linkID=9240617
    http://upandready.typepad.com/up_and_ready/2012/02/the-license-transfer-utility-doesnt-start.html
    Best Regards,
    Nicolas Ortiz Lara.
