• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Active Member
    Accepted Solution
    Revit 2013 Communication Failure? Communication Faliure when executing?
    5018 Views, 14 Replies
    09-09-2012 10:07 AM
    New Sager computer, Win 7 all updated, no virus software.
    Revit 2013 downloads to default folders, c: autodesk for setup and downloads folder for exe,  but get Communication Faliure error when I run the exe.
    Don't get what I'm doing wrong, not changing any folders, it should know how to install it self.  Yes, my interernet is on and working.
    I have tried freshly downloading 3 times.  over 3 days incase server was wonky.  No firewall on this side.
    Thank you, zowie
    Please use plain text.
    New Member
    Re: Revit 2013 Communication Failure? Communication Faliure when executing?
    09-09-2012 10:45 AM in reply to: kronoskiros
    I'm having the exact same issue when trying to install 3ds Max Design 2013 or Autocad 2013.  I have a Sager 9280 laptop w/ clean install of Windows 7 Pro 64.
    Active Member
    09-10-2012 10:56 AM in reply to: kronoskiros
    Does anyone associated with autodesk look at this group?  Is there a better place to post a question?
    philip.s
    09-10-2012 11:13 AM in reply to: kronoskiros
    Hi ahav and kronoskiros - We do indeed have a number of employees with varying backgrounds patrolling the Discussion Forums.
    The last cause listed on your attached image suggests that a firewall could be blocking the necessary ports. Have you tried temporarily disabling your firewall or opening up ports 80 and 443?
    Philip Schmelzer
    AutodeskHelp | Community Manager
    TW | PI | YT | BLOG
    Active Member
    09-12-2012 11:04 AM in reply to: kronoskiros
    It seems to have resolved when I added a mail client.  It seems it needed a default mail client so it could communicate.
    Perhaps this is why it didn't work on two new comptuers.
    philip.s
    09-12-2012 11:12 AM in reply to: kronoskiros
    Thanks for following up and closing the loop kronoskiros!
    Philip Schmelzer
    TW | PI | YT | BLOG
    Member
    11-24-2012 10:58 PM in reply to: philip.s
    I am getting this same pop up. I am using windows xp and have disabled firewall. How can I resolve this problem?
    New Member
    12-03-2012 08:03 AM in reply to: philip.s
    Whats a mail client? As in.. outlook? Do i have to install that to get this installed? Im getting the communication error...
    New Member
    12-04-2012 08:54 PM in reply to: philip.s
    i have open port 80 and 433 and also disable firewall but still doesnt work....How can i resolve it? can you fully amswer in a simple step structure please thanks :smileywink:
    New Member
    01-28-2013 05:09 PM in reply to: kronoskiros
    How is installing a mail client a solution to this problem???
    I have been trying over 5 days to install, I have disabled my antivirus and firewall. I have also tried the "browser download" and got a crappy lmza2 file. This problem is not exclusive to Revit either - i am having exactly the same issue with autocad 2013.
    This is not good enough autodesk, Im going to try and find a torrent.
