• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    Revit 2012 stuck in viewer mode - cant licence
    622 Views, 3 Replies
    03-01-2012 04:09 PM
    Hi - I have been rying to install Revit 2012.  I enter my serial number & product ID, go thru the installation process.  Start Revit & it is in viewer mode. I cant get to the licence stage - in other words I cant get out of viewer mode to go thru the steps of licencing the product. I let a trial version lapse - but have since got a home licence from my employer.  I have tried all suggestions that I could find from going to the start menu to select Revit A, to following the steps of removing all autodesk products from the system - going thru the regedit etc. http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
    Any thoughts - apart from re-installing windows?
    Please use plain text.
    TravisNave
    Re: Revit 2012 stuck in viewer mode - cant licence
    03-02-2012 08:17 AM in reply to: david_mac_user
    I assume you have a stand-alone activation?  Can you not activate the product once it is launched?
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    New Member
    03-03-2012 07:31 AM in reply to: TravisNave
    Spoiler
    Yes I have a stand alone licence.  I re-installed windows - a repair from the control panel.
    No further issues - installed OK.
    Member
    02-14-2013 11:11 PM in reply to: david_mac_user
    Hi
    David_mac
    I have the same problem.
    Could you describe the steps you took ?
    I'm on WIndows7. WHen you say you re-intalled windows does that mean you reformated?
