Installation & Licensing
New Member
trombocyt
Message 1 of 3 (442 Views)
Revit 2012 installation freeze-mess
442 Views, 2 Replies
09-26-2011 09:51 PM
Hi, I'm having a problem with installing revit 2012 (on Win7). The installation process froze on 3 out of 12 for several hours. Since there was no reaction to anything (cancelling, closing the window) i terminated the process. When I try to install it again, the wizard sees Revit as installed. And yes, the application is on the hdd, but simply doesnt work (freezes on splash). Neither does the uninstall option work.
How to get rid of the previous, not working application, and install Revit SUCCESSFULLY?
*Expert Elite*
TravisNave
Message 2 of 3 (428 Views)
Re: Revit 2012 installation freeze-mess
09-27-2011 09:14 AM in reply to: trombocyt
For more information on the Autodesk KB Support article concerning the clean uninstall of Autdoesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
Worst case, use the MSI Cleanup Utility at your own risk.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
New Member
trombocyt
Message 3 of 3 (407 Views)
09-28-2011 10:15 AM in reply to: trombocyt
Ok, the MSI Cleanup helped to remove Revit, but still, I cannot install a new copy. I run the setup as administrator, the anti-virus is off, I've enabled .NET, only recomended step i couldnt follow was changing this AlwaysInstallElevated parameter, as i Cannot find the key paths in registry..? I simply do not see the folder HKEY_CURRENT_USER\Software\Policies\Microsoft\Windows\Installer in regedit. Anyway, this is the message that appears during setup:
and after I click ok:
then, when i click ok the setup terminates and writes "couldnt install program". Any Idea what could help? I've tried re-downloading the setup, didn't help too.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
