Installation & Licensing
Revit 2012 install issue: C++ 2005 Redist Security Update
5 REPLIES 5
1334 Views, 5 Replies
The install stops at the MS Visual C++ 2005 SP1 Redistributable ATL Security Update.
2011/9/8:17:30:34    jdiamond    EQPT1028-V64    === Setup started on EQPT1028-V64 by jdiamond ===
2011/9/8:17:30:34    jdiamond    EQPT1028-V64    Launch
2011/9/8:17:31:03    jdiamond    EQPT1028-V64    Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64):   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="\\Tvs-cluster-projdata4-server\projdata4\Projects4\Deployments\Revit2012-64\AdminImage\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2011/9/8:17:31:12    jdiamond    EQPT1028-V64    Install    Microsoft Visual C++ 2008 KB958314 (ATL) (x64)    Succeeded
2011/9/8:17:31:12    jdiamond    EQPT1028-V64    Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64):   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="\\Tvs-cluster-projdata4-server\projdata4\Projects4\Deployments\Revit2012-64\AdminImage\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2011/9/8:17:31:28    jdiamond    EQPT1028-V64    Install    Microsoft Visual C++ 2008 KB958314 (MFC) (x64)    Succeeded
2011/9/8:17:31:28    jdiamond    EQPT1028-V64    Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64):   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="\\Tvs-cluster-projdata4-server\projdata4\Projects4\Deployments\Revit2012-64\AdminImage\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2011/9/8:17:31:40    jdiamond    EQPT1028-V64    Install    Microsoft Visual C++ 2008 KB958314 (CRT) (x64)    Succeeded
2011/9/8:17:31:40    jdiamond    EQPT1028-V64    Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64):   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="\\Tvs-cluster-projdata4-server\projdata4\Projects4\Deployments\Revit2012-64\AdminImage\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2011/9/8:17:31:50    jdiamond    EQPT1028-V64    Install    Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64)    Succeeded
2011/9/8:17:31:50    jdiamond    EQPT1028-V64    Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): \\Tvs-cluster-projdata4-server\projdata4\Projects4\Deployments\Revit2012-64\AdminImage\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\jdiamond\AppData\Local\Temp\vcredist_x86_2005.log"" "
2011/9/8:17:31:51    jdiamond    EQPT1028-V64    Install    Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86)    Failed    Installation aborted, Result=1603
2011/9/8:17:31:58    jdiamond    EQPT1028-V64    Rollback    Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64)    Succeeded
2011/9/8:17:32:02    jdiamond    EQPT1028-V64    Rollback    Microsoft Visual C++ 2008 KB958314 (CRT) (x64)    Succeeded
2011/9/8:17:32:08    jdiamond    EQPT1028-V64    Rollback    Microsoft Visual C++ 2008 KB958314 (MFC) (x64)    Succeeded
2011/9/8:17:32:11    jdiamond    EQPT1028-V64    Rollback    Microsoft Visual C++ 2008 KB958314 (ATL) (x64)    Succeeded
2011/9/8:17:32:14    jdiamond    EQPT1028-V64    === Setup ended ===
I need to get this resolved as soon as possible.  Any ideas?  I would like to remove the C++ 2005 and just reinstall, but can't seem to do so.
5 REPLIES 5
TravisNave
Try installing the prerequisite manually by downloading it from Microsoft.  Once correctly installed, your Autodesk installer should ignore it.
Autodesk Forums:
in reply to: TravisNave
Already tried that.  I've also ran the windows installer cleanup utility to uninstall some of the 2005 C++ updates that couldn't uninstall through Add/Remove Programs.
Are there some registry keys that need to be deleted for C++?  I had this problem trying to install 2011 last year; it's frustrating to have to go through this again.
TravisNave
Might be a tough cookie to fix.
Do you get errors when you try to install the link here?
http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=25287
Autodesk Forums:
For that installation package, it says that it doesn't support Win7.
TravisNave
Sorry, you didn't list your OS details.
http://www.microsoft.com/download/en/details.aspx?id=14431
Autodesk Forums:
Administrator Productivity
