The install stops at the MS Visual C++ 2005 SP1 Redistributable ATL Security Update.
2011/9/8:17:30:34 jdiamond EQPT1028-V64 === Setup started on EQPT1028-V64 by jdiamond ===
2011/9/8:17:30:34 jdiamond EQPT1028-V64 Launch
2011/9/8:17:31:03 jdiamond EQPT1028-V64 Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="\\Tvs-cluster-projdata4-server\projdata4\Projects4\Deployments\Revit2012-64\AdminImage\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/9/8:17:31:12 jdiamond EQPT1028-V64 Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2011/9/8:17:31:12 jdiamond EQPT1028-V64 Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="\\Tvs-cluster-projdata4-server\projdata4\Projects4\Deployments\Revit2012-64\AdminImage\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/9/8:17:31:28 jdiamond EQPT1028-V64 Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2011/9/8:17:31:28 jdiamond EQPT1028-V64 Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="\\Tvs-cluster-projdata4-server\projdata4\Projects4\Deployments\Revit2012-64\AdminImage\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/9/8:17:31:40 jdiamond EQPT1028-V64 Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2011/9/8:17:31:40 jdiamond EQPT1028-V64 Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64): ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="\\Tvs-cluster-projdata4-server\projdata4\Projects4\Deployments\Revit2012-64\AdminImage\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/9/8:17:31:50 jdiamond EQPT1028-V64 Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2011/9/8:17:31:50 jdiamond EQPT1028-V64 Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): \\Tvs-cluster-projdata4-server\projdata4\Projects4\Deployments\Revit2012-64\AdminImage\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\jdiamond\AppData\Local\Temp\vcredist_x86_2005.log"" "
2011/9/8:17:31:51 jdiamond EQPT1028-V64 Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2011/9/8:17:31:58 jdiamond EQPT1028-V64 Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2011/9/8:17:32:02 jdiamond EQPT1028-V64 Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2011/9/8:17:32:08 jdiamond EQPT1028-V64 Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2011/9/8:17:32:11 jdiamond EQPT1028-V64 Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2011/9/8:17:32:14 jdiamond EQPT1028-V64 === Setup ended ===
I need to get this resolved as soon as possible. Any ideas? I would like to remove the C++ 2005 and just reinstall, but can't seem to do so.
Try installing the prerequisite manually by downloading it from Microsoft. Once correctly installed, your Autodesk installer should ignore it.
Already tried that. I've also ran the windows installer cleanup utility to uninstall some of the 2005 C++ updates that couldn't uninstall through Add/Remove Programs.
Are there some registry keys that need to be deleted for C++? I had this problem trying to install 2011 last year; it's frustrating to have to go through this again.
Might be a tough cookie to fix.
Do you get errors when you try to install the link here?
http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=25287
Sorry, you didn't list your OS details.
http://www.microsoft.com/download/en/details.aspx?id=14431
