Installation & Licensing
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Revit 2012 architectu re failed to install.SO S!!!!
- Highlight
- Email to a Friend
- Report Inappropriate Content
2013/3/4:11:36:28 TINGRU YANG TINGRUYANG === Setup started on TINGRUYANG by TINGRU YANG ===
2013/3/4:11:36:28 TINGRU YANG TINGRUYANG Launch
2013/3/4:11:37:07 TINGRU YANG TINGRUYANG === Setup ended ===
2013/3/4:11:36:30 TINGRU YANG TINGRUYANG === Setup started on TINGRUYANG by TINGRU YANG ===
2013/3/4:11:36:30 TINGRU YANG TINGRUYANG Launch
2013/3/4:11:37:00 TINGRU YANG TINGRUYANG PageOpen LaunchDialog
2013/3/4:11:37:47 TINGRU YANG TINGRUYANG PageOpen LicenseDialog
2013/3/4:11:37:59 TINGRU YANG TINGRUYANG PageOpen ProductInfoDialog
2013/3/4:11:38:46 TINGRU YANG TINGRUYANG PageOpen ProductSelectionDialog2
2013/3/4:11:39:09 TINGRU YANG TINGRUYANG PageOpen FullProgressDialog
2013/3/4:11:39:09 TINGRU YANG TINGRUYANG Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_Archi
2013/3/4:11:39:21 TINGRU YANG TINGRUYANG Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2013/3/4:11:39:21 TINGRU YANG TINGRUYANG Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_Archi
2013/3/4:11:39:38 TINGRU YANG TINGRUYANG Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2013/3/4:11:39:38 TINGRU YANG TINGRUYANG Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_Archi
2013/3/4:11:39:52 TINGRU YANG TINGRUYANG Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2013/3/4:11:39:52 TINGRU YANG TINGRUYANG Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_Archi
2013/3/4:11:40:05 TINGRU YANG TINGRUYANG Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2013/3/4:11:40:05 TINGRU YANG TINGRUYANG Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_Engli
2013/3/4:11:40:13 TINGRU YANG TINGRUYANG Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2013/3/4:11:40:16 TINGRU YANG TINGRUYANG Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Failed Installation aborted, Result=1618
2013/3/4:11:40:19 TINGRU YANG TINGRUYANG Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Failed Installation aborted, Result=1618
2013/3/4:11:40:22 TINGRU YANG TINGRUYANG Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Failed Installation aborted, Result=1618
2013/3/4:11:40:25 TINGRU YANG TINGRUYANG Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Failed Installation aborted, Result=1618
Re: Revit 2012 architectu re failed to install.SO S!!!!
- Highlight
- Email to a Friend
Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again. If that fails, install the update directly from Microsoft then try the installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensi
Keep in mind that you can modify the setup.ini per the link above if the first steps fail to resolve your issue.
Good Luck!
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
